2017 M8 114" TTS-200 cam - Road Glide Forums
 2Likes
  • 2 Post By Mainecat
post #1 of 5 (permalink) Old 03-09-2018, 09:15 PM Thread Starter
SE stage 3
TTS-200 cam
Stock heads
SE 64MM TB/injectors
SE heavy breather
Fulsac head pipe
Forsch slip on's
TTS Mastertune
RJ111 and Hawkman like this.
Mainecat is offline
post #2 of 5 (permalink) Old 03-10-2018, 04:37 PM
Very nice. Back tire is gonna hate you.
Dave I. is offline
post #3 of 5 (permalink) Old 03-10-2018, 10:46 PM
Swomack's Avatar
Great Numbers
Enjoy That
Congrats
Swomack
My Gallery / Click Below Link
Swomack is offline
post #4 of 5 (permalink) Old 03-11-2018, 07:17 AM
madmat's Avatar
That looks like a fun ride!
18 RGS Bonneville Salt Pearl
madmat is offline
post #5 of 5 (permalink) Old 03-13-2018, 09:25 PM Thread Starter
Had it tuned as I added the SE 64 MM TB/injectors. It was 127/114 with the stock TB, but that dyno run was in SAE. This was tuned in 55 degree weather so its STD which reads about 2.6 higher on both tq and hp. So realistically its closer to 131/119. Gives you an idea what the SE TB did. This is a 5th gear pull.
As far as from a driveability standpoint, very noticeable. Increased torque from 107 to 112 right off idle, so it is snappier down low and pulls harder across the rpm band. Worth the upgrade imo.
Mainecat is offline
2017 CVO 114" Milwaukee 8 Wood WM8-222 cam fuelmoto Dyno Results 5 06-02-2019 08:19 PM
114" M8 stage III cylinders/pistons etc... mtharston Parts for Sale 0 05-02-2018 08:58 PM
Fuel Moto M8 124" big bore kit 114 & 117 engines fuelmoto Fuel Moto 0 01-11-2018 12:09 PM
'18 114-in Stage=4 with TTS cams and TTS tuner Sharkbreath Dyno Results 12 12-16-2017 10:02 AM
Looking for a dyno--114 w/ Woods M8-408 cam rustyj671 Dyno Results 8 06-02-2017 07:30 AM
