19 CVO 117 w Stg 3 - Road Glide Forums
  • 1 Post By SteadyEddie
post #1 of 4 (permalink) Old 12-13-2018, 09:59 PM Thread Starter
NewSchoolBagger's Avatar
19 CVO 117 w Stg 3
Just did a 117ci stage 3 kit on my 19 CVO RG (mako). Using jackpot 2/1/2 head pipe 4" magnaflow mufflers and PV tuner from Fuel Moto stage 3 map. Just asking if anyone did this on the 18 or 19 cvo 117ci and if they did a dyno? if so what were your overall numbers. was curious to see what i might be at before i do a dyno run.
thanks
19' CVO RG Mako Fade stage 3
12' RGC- Big Blue Pearl
Balls to the Walls!
NewSchoolBagger is offline
post #2 of 4 (permalink) Old 12-14-2018, 08:53 AM
SteadyEddie's Avatar
Not the same but for compare sake, my Stage 2 117 on my '18 CVO has stock header pipe and Reinfart 4s with the SE Tuner and Power Cam and I am at 107HP and 127FPT with a lovely pull sheet and power through out the entire spectrum
What Cam are you going with for your S3 as well as other components outside of what you listed?
Rubimad likes this.
SteadyEddie is offline
post #3 of 4 (permalink) Old 12-14-2018, 02:57 PM Thread Starter
went with straight out the box stage 3 kit 498 HD cam it stays a 117ci motor just goes to 11:1 compression with cylinders and pistons.thx
Balls to the Walls!
post #4 of 4 (permalink) Old 12-14-2018, 03:03 PM Thread Starter
Fuel moto shows a dyno chart of a stock 2018 117ci 94 HP 110 Torque. his stock tune gets it to 95 HP and 111 torque. his numbers with a full exhaust and tune is 104 and 123. i am hoping to be at 115-120hp and 130-135 torqu with stage 3 setup.
Balls to the Walls!
CVO 2013 117 kit D snake Dyno Results 19 03-27-2017 07:09 AM
110 drop in, CVO w/Mods, 117 drop in Lou Dude Dyno Results 1 03-08-2017 07:59 AM
CVO 117 dyno help ClinesSelect Dyno Results 11 02-12-2017 08:35 PM
Need a 117 base map for pcv tman 625s and worked heads any 117 mapwill work using aut mitchdm ECM/Fuel Management systems 3 05-16-2014 09:31 AM
WTT: 19" Front Agitator Contrast for 19" Front Black Agitator Mario77746 Wanted! (Buy or Trade) 2 08-19-2012 03:35 PM
