2019 RGS w/Zippers 468 - Page 2 - Road Glide Forums
 25Likes
post #11 of 34 (permalink) Old 01-27-2019, 06:26 PM
If he's got a 19 RGS, it's a 114" motor.
Originally Posted by Dmerch View Post
Nice torque! What size engine?
fairlydangerous1 likes this.
RoadglideinMO is offline
post #12 of 34 (permalink) Old 01-27-2019, 08:47 PM Thread Starter
fairlydangerous1's Avatar
Yep, stock 114 with just air cleaner, cam, Power Vision tuner and heavier clutch springs.
fairlydangerous1 is offline
post #13 of 34 (permalink) Old 01-27-2019, 08:55 PM
Good numbers, especially for a basically stock engine.
post #14 of 34 (permalink) Old 01-28-2019, 10:20 AM Thread Starter
I had already bought the parts for this build in the beginning right after I got the bike (no, I can never leave anything alone).
But, the next step probably this coming fall will be 120" bore with a little more compression, Zippers 472 cam, 64mm TB, injectors, and lock up clutch. That should give me about the same power now with a passenger loaded with gear. I don't need more than I have now unloaded by myself. Don't want to out-power the rear tire or transmission. Don't care about the dyno numbers, just the feel of the bike get'n it!
But for now enjoying the ride.
Wife says I'm crazy.....I'm not. Just fun to play.
post #15 of 34 (permalink) Old 01-28-2019, 10:29 AM
BigBlockBobby's Avatar
How about a little sound clip? Great numbers btw.
BigBlockBobby is offline
post #16 of 34 (permalink) Old 01-28-2019, 11:31 AM Thread Starter
I can try with the phone tonight but my experience is you just don't get the "pop" this thing has. you would swear I'm running really high compression with snap in the sound but just stock.
BigBlockBobby likes this.
post #17 of 34 (permalink) Old 01-30-2019, 10:15 AM Thread Starter
Did a video with my phone but the sound is NOTHING like it really sounds so no point in posting. I don't think the phone thing works.
post #18 of 34 (permalink) Old 01-30-2019, 10:55 AM
Little Wing's Avatar
those are very impressive numbers for basically a stage 2 engine with a long duration cam...
i would have expected some cylinder and/or head work would be in order to achieve that amount of torque that low in the revs.
had you done anything to the top end at all?
'18 FLTRX • '04 BAR HOPPER • '94 FLSTCTHE BEST BIKE ...is the one you're on!!!
Little Wing is offline
post #19 of 34 (permalink) Old 01-30-2019, 01:26 PM
RGKen's Avatar
You'd be surprised how well the stock heads flow. Unless you are going to the larger TB and injectors, and more cubes like the 124"/128"the stock heads flow surprisingly well. That's why some of these aftermarket cams are yielding some impressive numbers. Its just not a crucial as it was on the TC's to do headwork only now the bar is getting higher so it is all relative.
2018 FLTRXS
RGKen is offline
post #20 of 34 (permalink) Old 01-30-2019, 02:23 PM
i'm not surprised about the M8 head flow at all.
that and the super efficient combustion are the biggest reasons i bought one.
with 2 intake valves they must have increased velocity, also, because air can get lazy real quickly with higher volumes.
being able to maintain volumetric efficiencies with software these days is really cool for an old carb guy.
i usually refer to FuelMoto's dyno charts for comparison because they're usually conservative (read honest)
to get anywhere close to the OP's 120 ft.-lbs of torque at 2,250 rpm would require a 120" engine & head mods according to their website.
just haven't seen this kinda torque that low in the rev band to compare it to.
woulda thunk it had more displacement.
it is very impressive!
RGKen likes this.
So Has Anyone Pulled The Trigger On A 2019 Roadglide Yet ? Swomack *General Road Glide Discussions/Pictures 285 03-13-2019 10:33 PM
2015 RGU CVO vs 2019 RGU Prolific *General Road Glide Discussions/Pictures 26 09-23-2018 01:34 PM
2019 Dynojet Power Vision Now Available fuelmoto Fuel Moto 0 09-14-2018 09:45 AM
2019 harley colors are here!!! ynotbmester *General Road Glide Discussions/Pictures 99 08-25-2018 05:35 PM
