Not thrilled with my results - Page 2 - Road Glide Forums
 4Likes
post #11 of 14 (permalink) Old 03-14-2019, 02:28 PM
There is all kinds of tricks to the trade. Numbers can be fudged. Air in and out of the back tire, all kinds of stuff. But if you look at the runs this guy post on the tech forum, he does some seriously nice work. Also nobody is just handing out compliments on that forum. If something is off guys call them out on it. Lot of experienced engine builders and tuners over there.
It might not be the "Best" sheet he has posted, I just linked it because it was right there.
phillyfan1 is offline
post #12 of 14 (permalink) Old 03-14-2019, 03:33 PM
RGKen's Avatar
You may be misunderstanding my point. I even said I wasn't bashing the tuner. I know that shop does great work and when I said some shops will do things like that to make the curve look flatter I have no idea if he does or not as it was just a statement so there is no need to defend him at all. Just pointing out a little bit of an optical twist to it. That's all.
Also, by mentioning the dip I was critical of the exhaust match to that cam and not the tuner. Not always the tuners fault. Sometimes you can only do so much with what you have to work with. That exhaust may work much better with a different cam or that cam might work better with a different exhaust. Might not be the optimal pairing but obviously works pretty well past that point.
2018 FLTRXS
RGKen is online now
post #13 of 14 (permalink) Old 03-14-2019, 06:56 PM
HellInABucket's Avatar
Originally Posted by SJA66 View Post
the SE Pro Race Tuner (orange), it was done at a Harley Dealer, not sure who the guy was. They told me I essentially replaced the stock cam with a nearly identical aftermarket cam.
In the absence of other information, I'd say this was your first mistake.
2018 FLTRU
Roll away the dew...
HellInABucket is offline
post #14 of 14 (permalink) Old 03-14-2019, 08:08 PM
Ken, I guess you misunderstood my point. I agree with you on all aspects. All of this stuff can be manipulated to look however the tuner wants it too.
I was trying to point out that Darren is a very well respected tuner among his peers. I spoke to him at length before I chose my cams. He was very professional and he gave me his suggestion, and I wasn't even buying anything from him.
All good brother
Can anyone explain these results? '17 RGU Stage 1 LuzRD Dyno Results 8 07-11-2017 09:35 PM
The results of my dental experience in Mexico ironmark General Off-Topic Discussions 19 02-19-2017 12:06 AM
My Dyno Results Budd559 Dyno Results 12 09-17-2015 09:24 PM
Stock Dyno results 1st Sgt ECM/Fuel Management systems 17 03-03-2012 04:12 AM
Dynojet Results - Stage 1 complete jonesbrass Intake and Exhaust 10 12-20-2010 09:18 AM
