Not thrilled with my results - Road Glide Forums
 4Likes
post #1 of 14 (permalink) Old 03-12-2019, 04:00 PM Thread Starter
SJA66's Avatar
I have a 2015 RGS , I Installed Cyclerama 570-2 cams, S&S lifters and pushrods, and all I gained was 2HP and half a foot pound of torque. I attatched an older dyno and the new one. I have the SE Pro Race Tuner (orange).The older dyno is from when I installed D&D Fatcat 2-1 and the SE heavy breather elite, the second one is with the cams added. Its a 2015 103HO rushmore engine, it feels better, but dam I thought I would have higher numbers. Any thoughts on this are appreciated, is this normal numbers for whats installed.
SJA66 is offline
post #2 of 14 (permalink) Old 03-12-2019, 04:09 PM
What tuner are you using and who was the technician running the dyno ?
post #3 of 14 (permalink) Old 03-12-2019, 04:12 PM Thread Starter
SJA66's Avatar
the SE Pro Race Tuner (orange), it was done at a Harley Dealer, not sure who the guy was. They told me I essentially replaced the stock cam with a nearly identical aftermarket cam.
SJA66 is offline
post #4 of 14 (permalink) Old 03-12-2019, 08:17 PM
Road dawg's Avatar
Not familiar with that Cyclerama brand , but yea I would be disappointed as well. I run either Feulings or Woods or even Andrews all with good results, something is not right here.
Road dawg is offline
post #5 of 14 (permalink) Old 03-12-2019, 08:46 PM
Thermodyne's Avatar
Those are pressure cams, for stock motors. So 100+ torque down low and done by 4500. You picked up a little torque down low, but the 103HO already came with a more of a torque cam than the earlier 103's. And those 570's tend to ping, so the tune could have some spark backed out, especially with a used motor that's going to have some carbon in the cylinders.
You can make 100HP easy, with just a different cam swap. But its going to cost you some of that low end grunt.
JacktheBagger and Ickshter like this.
Thermodyne is offline
post #6 of 14 (permalink) Old 03-13-2019, 10:08 AM
Shefffer Performance has a bunch of sheets listed on the tech forum with those cams. How many miles on the bike?
First, how does it run? thats the most important factor.
Second, if you don't like how its running take to a indy that has a good rep. They might not want to use your tuner though.
Momania likes this.
phillyfan1 is online now
post #7 of 14 (permalink) Old 03-13-2019, 01:37 PM
Momania's Avatar
Phillyfan I see you have the Cyclerama 575 as do I and that cam runs great, wish I could find where I put my Dyno Sheet I had it installed and tuned by Cyclerama, but I got plenty of bag for my buck. I worked at my local HD dealer and I wouldn't let them tune my bike you are correct about finding an indy.
nytryder likes this.
Momania is offline
post #8 of 14 (permalink) Old 03-13-2019, 01:56 PM
Here is one that was posted on this site. Look at how flat the lines are. QUALITY tune.
https://www.roadglide.org/26-engine-...uestion-2.html
post #9 of 14 (permalink) Old 03-14-2019, 01:17 PM
tj316's Avatar
Id call Wes Brown at Cycle Rama and talk to him . Wes has built two motors for me. He is super friendly and knowledgeable without an attitude like most engine builders. He can give you ideas based on your setup.
tj316 is offline
post #10 of 14 (permalink) Old 03-14-2019, 02:21 PM
RGKen's Avatar
If you are referring to post #11 by George W.
Not saying this isn't a quality tune but you have to pay attention to these dyno sheets and how they are scaled when they are printed out if you are just going by the shape of the curves. This on is compressed top to bottom and stretched out left to right so it's not near as flat as you think it is. Some tuners do this intentionally to give that illusion.
Still pretty good peak numbers but may not be the best exhaust for that cam down low just looking at the dip in tq there.
2018 FLTRXS
RGKen is offline
Can anyone explain these results? '17 RGU Stage 1 LuzRD Dyno Results 8 07-11-2017 09:35 PM
The results of my dental experience in Mexico ironmark General Off-Topic Discussions 19 02-19-2017 12:06 AM
My Dyno Results Budd559 Dyno Results 12 09-17-2015 09:24 PM
Stock Dyno results 1st Sgt ECM/Fuel Management systems 17 03-03-2012 04:12 AM
Dynojet Results - Stage 1 complete jonesbrass Intake and Exhaust 10 12-20-2010 09:18 AM
