Dyno Pull - Road Glide Forums
post #1 of 5 (permalink) Old 07-15-2013, 03:05 PM Thread Starter
Dyno Pull
2011 FLTRX; SE 254E; SE AC breather; 2-1 Fat Cats and SE race Tuner.
Kerryebro is offline
post #2 of 5 (permalink) Old 07-15-2013, 04:09 PM
scooterroid's Avatar
Nice. Great numbers. What base map did your tuner use?
Scoots
scooterroid is offline
post #3 of 5 (permalink) Old 07-15-2013, 04:52 PM
mocotom's Avatar
Very nice looking curve and not bad numbers. Your actually running fairly lean a/f for a WO pull, and could possibly gain some if you were closer to 12.8 or 13.0 to 1. Make sure your not pinging at WO throttle running that lean.
2005 RG 98cu in
USMC 1968-1972
mocotom is offline
post #4 of 5 (permalink) Old 07-15-2013, 08:13 PM
Wooden Nickel
Guest
Posts: n/a
That was the issue with mine having the A/F to high and thus running lean. Mine was running as high as 15 and as low as 14. Once Travis my tuner adjusted it to the upper 12's to 13 I gained 5+ HP and just under 5 lb's of TQ. You still have some room to improve your numbers. Mine also runs cooler now.
post #5 of 5 (permalink) Old 07-17-2013, 01:54 PM Thread Starter
Scoots
Its not tuned, just pulled dyno prior to getting it done.
+4 Cam Key Dyno Pull BlackDangerous Engine Related 7 06-09-2017 06:30 AM
First Time Dyno pull over the weekend. Stick_FSMC Dyno Results 3 03-30-2016 10:46 AM
Anyone pull a trailer with your Road Glide? Gar *General Road Glide Discussions/Pictures 55 01-04-2012 06:01 AM
A Speedo and a pull... BLKNCr6 Videos 2 08-30-2011 11:24 AM
