07 103" Roadglide, Stock Heads, 255's - Road Glide Forums
post #1 of 25 (permalink) Old 02-27-2011, 07:18 PM Thread Starter
hdxbones's Avatar
2007 103" SE flat tops & jugs, stock heads, SE 255's, V&H True Duals w/Rush slip-on's, Forcewinder intake, SERT, & a perfect tune by Big Boyz in Maine.....
Ridin' Roadglides before they were cool.......
hdxbones is offline
post #2 of 25 (permalink) Old 02-27-2011, 10:16 PM
SharkNose's Avatar
I'm interested as I have a similar build except PC-V and autotune, but didn't see and dyno info attached.
SharkNose is offline
post #3 of 25 (permalink) Old 02-28-2011, 11:48 AM Thread Starter
hdxbones's Avatar
That is the dyno run.... what info would you like?
hdxbones is offline
post #4 of 25 (permalink) Old 02-28-2011, 12:18 PM
allofus81's Avatar
Perhaps we are looking for a Dyno Sheet as thats what this thread is for. You gave us the info as to what you had installed but no dyno sheet. What hp and tq did you get out of this build!?
allofus81 is offline
post #5 of 25 (permalink) Old 02-28-2011, 12:23 PM
SharkNose's Avatar
Yep...what he said!
post #6 of 25 (permalink) Old 02-28-2011, 12:50 PM Thread Starter
hdxbones's Avatar
It is posted as an image- shows up on my screen, maybe you have something blocked in your settings? Try it as an attachment-
hdxbones is offline
post #7 of 25 (permalink) Old 02-28-2011, 01:11 PM
SharkNose's Avatar
I see it now since you reposted in last repsonse.
Looks like nice smooth curves
post #8 of 25 (permalink) Old 02-28-2011, 03:24 PM
I didn't see anything on the first post either, numbers look pretty good, looks like enough torque to pull a train.
post #9 of 25 (permalink) Old 03-01-2011, 10:39 AM
I used the SE 103 kit with the 255 cams with the STOCK heads and a HD race tuner , using Vance & Hines true duels & a K&N air filter . The bike dynoed out with max HP 84.94 & max torque 107.20 . IMO this is a great engine build for the average rider , the build is economical & dependable & gives you the power you need for touring whether you are riding by yourself or riding 2 up . Putting another $2,000 into heads will only get you another 8lbs or so of torque and that's not much bang for the buck $$$ . IMO use the stock heads until the heads need to be reworked , put the $2,000 in extra bling and ride .
post #10 of 25 (permalink) Old 03-14-2011, 12:43 AM
schuldtp's Avatar
Why not just set of SE204 cams and a tune. Lot more cost effective for almost matching results.
Paul in Alaska
schuldtp is offline
103 stock heads stock TB 11.0 pistons SE585 cam. Tuned by Stroker freedom1974 Dyno Results 8 02-01-2018 11:38 AM
WTB - stock 103 heads/kw 12" blk/drk Uncleford Wanted! (Buy or Trade) 8 09-28-2013 02:42 AM
CVO 255 cams (AKA SE-255) cams pat123 Parts for Sale 3 07-26-2013 09:58 AM
twin cam 96" heads/103" cylinders and pistons JKRSDETROIT Parts for Sale 2 05-18-2013 09:03 PM
