My results - Road Glide Forums
post #1 of 5 (permalink) Old 03-02-2011, 06:16 AM Thread Starter
Peewee's Avatar
My results
I put my bike on the dyno the other day and here are my results:
Stock 96" motor with KlockWerks Double Back head pipe, flowing thru a set of Wild Pig Slip-on's and Ventilaltor Air Cleaner. And the download from the dealership.
67.05 hp / 73.95 tq
"Know Thyself"
Peewee is offline
post #2 of 5 (permalink) Old 04-24-2011, 09:13 PM Thread Starter
Peewee's Avatar
Ok, I don't have my latest sheet with me, but here goes. It seems that just swapping slip-ons to the Klock wreks WFB's I picked up 3 ft/lbs. I then swapped out the air filter element (I'm running the Ventilator from the MoCo) to the K&N replcement. I picked up 1.5 hp and lost a little under 1 ft/lbs. I would like to point out that we (me and the tech) forgot to turn on the cooling fans in the dyno before the second run (the runs with the K&N), so there was probably some power loss due to heat. Matter of fact when I got to looking at the tech info the temp in the dyno was 3 degrees warmer, so you can guess how much hotter the motor was! All in all, I would say for a retail price of about $55 bucks, the gain of 1+ hp is worth it
"Know Thyself"
Peewee is offline
post #3 of 5 (permalink) Old 04-24-2011, 09:42 PM
BigDaveOnBass's Avatar
Send a message via Yahoo to BigDaveOnBass
Pee Wee, do you have a Race Tuner or other EFI controller? When I did the stage 1 a/c, SE slip ons and the SERT on my '04 (at the 5000 mile mark,) I was making 71 HP and 78 ft./lbs. with an 88" motor. You should have better numbers with a 96" motor.
I need to bring my bike down for a dyno run. With all the schtuff I've done to my motor, I'm hoping to get numbers between 85-95 HP and 90-100 ft./lbs. torque.
'04 FLTRI, originally Smokey Gold, now Vivid Black, 95", S/E forged high comp 9.6:1 pistons, Andrews 37G cams, Big Boyz heads, S/E adjustable pushrods, S/E Race Tuner, S/E Stage 1 kit, V&H Dresser Duals, S/E slip ons, H-D premium oil cooler, chromed wagon wheels, Brembo/H-D front brakes, added rear engine guards, Paul Yaffe 10" OEM Monkey Bars, detachable tour pak
BigDaveOnBass is offline
post #4 of 5 (permalink) Old 04-25-2011, 05:58 AM Thread Starter
Peewee's Avatar
No Race Tuner, just the download. I'm still trying to figure out what, if anything I wanna do motor wise. As far as the fuel curve, it is pretty well dead on. After talking to Roger, I may do cams. Funny you mention about the number though, I was thinking the same thing, my '03 got better numbers
"Know Thyself"
Peewee is offline
post #5 of 5 (permalink) Old 04-25-2011, 06:03 AM
ichiban's Avatar
IMHO:Ahhh, You have to get a tuner
ichiban is offline
My Power Vision Auto tune results. LL Cool K ECM/Fuel Management systems 137 06-06-2017 06:15 PM
My 98" Build Results BlackDangerous Dyno Results 6 06-03-2013 10:22 AM
Awesome Results on my 103 SIG556 Engine Related 2 05-11-2013 11:48 PM
Disappointed on the dyno results on my stage IV ironmark Engine Related 24 05-10-2013 01:10 PM
My Traxxion-Monotube Results DOOFUS Suspensions 10 02-06-2012 10:17 AM
