Disappointing dyno - Road Glide Forums
post #1 of 12 (permalink) Old 08-05-2013, 12:13 PM Thread Starter
Deadstroke's Avatar
Disappointing dyno
Well my Andrews 57 H today Dynoed at 91.5 horsepower 97torque. was hoping for 95 or 96.
2014 - Street Glide - 107 Motor
2015 - Road Glide - Stage 3 Blower Motor & Aerocharger
Deadstroke is offline
post #2 of 12 (permalink) Old 08-05-2013, 12:30 PM
NorCal's Avatar
post your dyno sheet so we can see the curve
NorCal is offline
post #3 of 12 (permalink) Old 08-05-2013, 01:23 PM Thread Starter
Deadstroke's Avatar
post #4 of 12 (permalink) Old 08-05-2013, 01:58 PM
pat123's Avatar
Looks ok to me. What exhaust are you running? Who tuned it? I always hated going to the dyno. I never got what I wanted and then it always costs me a ton of money. Now if I'm happy on how it rides or drives I stay away from the dyno.
Are you happy with it before going to the dyno?
pat123 is offline
post #5 of 12 (permalink) Old 08-05-2013, 02:04 PM
Banned
Well I can tell you that my set up
Vance and Hines Power duals with Their Monster rounds slip ons, SE air cleaner and Dyno using SERT was around
95hp 85TQ
Sent from Motorcycle.com App
Scootin is offline
post #6 of 12 (permalink) Old 08-05-2013, 02:46 PM
spokanebagfan's Avatar
one of the largest variables that aren't really discussed with every dyno is the parameters that the tester chooses, so if it feels good to ride i would not be overly concerned with the numbers.
spokanebagfan is offline
post #7 of 12 (permalink) Old 08-05-2013, 03:11 PM
throttles&triggers's Avatar
There are other variables in the equation. Here is a 103" that apparently made 92 hp and 103 tq with the Andrews 57H cams.
I had a 2005 CVO 103" that eventually Dynoed in at 102 hp and 103 tq with true duals, Stage 1 and PCIII. Depends on how they are programmed and mapped.
throttles&triggers is offline
post #8 of 12 (permalink) Old 08-05-2013, 03:34 PM
Wooden Nickel
Guest
Posts: n/a
Originally Posted by Deadstroke View Post
If you notice, your ARF is too lean. Bringing it down to 13:1 will give you that extra HP & TQ. I'd have him fix it because that isn't right.
I had the same on my bike. Fullsac head pipes, V & H Monster Rounds, SE Pro Race Tuner, Andrews 54H Cams done with a smart tune. My AFR was high and once he got it down to 13:1 I got the additional I was looking for. +5 HP & almost 5 TQ
post #9 of 12 (permalink) Old 08-05-2013, 04:36 PM
tdkkart's Avatar
The motor is carrying the torque well, had the dyno guy richened the mixture a bit and turned it to 6200 and it probably would have made a couple more HP.
tdkkart is offline
post #10 of 12 (permalink) Old 08-05-2013, 04:44 PM Thread Starter
Deadstroke's Avatar
Great thanks I PV I was using the auto tune to get it right,, now sure how to change the mixture on it with it but Ill give it a try..
And thanks to everyone who has responded to my post !!!!
Disappointing Build Deadstroke Engine Related 58 08-13-2018 03:58 PM
Dyno Run from Direct Link Install Shrug ECM/Fuel Management systems 6 06-07-2010 10:32 AM
