Dyno results with Mods Andrews Cams - Road Glide Forums
post #1 of 7 (permalink) Old 08-10-2013, 06:08 PM Thread Starter
sampson104's Avatar
Spent the morning at Robs Dyno this morning in Gardner Mass getting my 13' Road Glide dialed in after the Andrews 57H cams were installed. My mechanic was doing auto tunes on my SERT for me but the bike was running way lean and starving for fuel after the cam install, just wasn't getting anywhere fast at that point, ran rough on the throttle on low and popped on decal.
Mods to date:
V&H Power Duals x-pipe
V&H Hi output mufflers
SE Ventilator AC
SE race tuner pro
Andrews 57H Cams
Dyno results on arrival 92.1Hp - 109.9 ft-lbs tq (running like crap, was real lean, had more power than stock but was not very rider friendly)
After 2.5 hours on dyno 95.2HP - 113.2 ft-lbs tq (constant pull with no issues, runs better than a new stock bike but with more ponies) Freaking pulls nicely!
sampson104 is offline
post #2 of 7 (permalink) Old 08-10-2013, 06:30 PM
Eric92's Avatar
Very nice, i'd be happy with that.
2011RGC/VIVID BLACK/103
Eric92 is offline
post #3 of 7 (permalink) Old 08-10-2013, 07:34 PM
Easyryder01's Avatar
Those look like nice numbers. Looks like it starts off in the nice 2-2500rpm range and climbs.
2017 RGS Velocity Red
Easyryder01 is offline
post #4 of 7 (permalink) Old 08-11-2013, 08:25 AM
mocotom's Avatar
Rob is one of the best tuners in the northeast. Glad your happy.
2005 RG 98cu in
USMC 1968-1972
mocotom is offline
post #5 of 7 (permalink) Old 08-11-2013, 09:56 AM Thread Starter
sampson104's Avatar
Little light on HP & TQ down low, real nice mid & high RPM's.
Rob @ Robs Dyno showed me a chart from a customer of his using S&S 551 cams, TQ & HP are start much higher at 1,800-2,000 rpm's (like 95tq - 50hp) but drop drastically when approaching the mid 3,500 rpm area.
Its all in riding preference & style, if your a 2-up rider I'd be thinking the 551's would be real beneficial. I'm pretty aggressive on the throttle and don't spend a lot of time down low under 2,500.
post #6 of 7 (permalink) Old 08-11-2013, 09:59 AM Thread Starter
sampson104's Avatar
Rob spends the time to explain everything he is doing to your bike while your watching him tune. His operating system he uses to adjust the air/fuel mixture is an absolute science, Grade A+! Highly recommend this shop!
post #7 of 7 (permalink) Old 08-17-2013, 04:01 PM
ERod62's Avatar
Thumbs up
Nice numbers. Have similar setup, love it. Dyno chart almost identical, my air fuel was flat about 13.1 across.
Nothing like a good tune. Ran through the same issues until DOC's Performance tune it. Gained some hp and tq, the biggest gain was riding... total different ride after.
Enjoy the ride.
ERod62 is offline
Tags
57h
Dyno results 103" TW-777 cams Brianu1 Dyno Results 20 03-14-2016 02:16 PM
Andrews 26 to Andrews 57 Bill-99RG Engine Related 2 02-29-2016 06:28 AM
Dyno with 96" and Andrews 48h cams. MichiganRider Dyno Results 8 04-21-2014 11:09 AM
did cams today. dyno results waynemags Dyno Results 7 05-28-2013 04:29 PM
Andrews 48H results. ozzyblu Engine Related 18 04-01-2012 11:57 AM
