Added Cams Andrews 55H - Road Glide Forums
post #1 of 3 (permalink) Old 08-11-2013, 10:34 PM Thread Starter
I was looking to have 57H cams put in my bike but the Tech suggested 55H cams
It came out pretty good but I still wonder if I would have been better off with the 57H cams
HP 95.40 TQ 102.90
I have checked my milage once since the install and I got 43mpg on that tank.
Question : How much more would I gain if I put ported heads on and would I have much reduction in mpg?
Bikejockey is offline
post #2 of 3 (permalink) Old 08-12-2013, 08:01 PM
Wooden Nickel
Guest
Posts: n/a
If you wanted a low end torque cam with a nice long torque curve, he talked you into the wrong cams. These were designed for 9.8 to 10.2 compression ratios and they are a mid range HP and TQ cam. As you can see on your dyno sheet they don't come on early and they don't last long. Sorry.
post #3 of 3 (permalink) Old 08-17-2013, 04:22 PM
ERod62's Avatar
Hope it work for you but 57H sure hold longer and come on early enough for low speed crusing, am aggressive on the throttle works great on a stock motor.
Spend the money on the upgreat if the bike runs great just enjoy it.
ERod62 is offline
cams,cams,cams dozer23 Engine Related 2 03-03-2017 09:18 AM
Andrews 26 to Andrews 57 Bill-99RG Engine Related 2 02-29-2016 06:28 AM
55h cams Bikejockey Engine Related 1 01-27-2013 10:10 PM
Andrews 48H cams sportyguy69 Engine Related 1 11-25-2010 06:57 PM
Andrews 48H Cams are in... FLTRI *General Road Glide Discussions/Pictures 27 11-01-2010 11:07 PM
