2013 fltrx 103 - Road Glide Forums
post #1 of 11 (permalink) Old 08-21-2013, 10:34 AM Thread Starter
flatlander's Avatar
2013 fltrx 103
Had my new 2013 FLTRX tuned and dyno'd at Alefs HD in Wichita this past weekend. I am happy with the results although I was hoping for more. Bike runs great and pulls very good running down the road
HP was at 89
TQ was at 102
103 motor with 254e cams, Heavy Breather, TTS, Rinehart Classic True Duals w/3.5 inch cans...nothing fancy.
My wife's 2013 Streetglide has the same setup minus the cams and dyno'd at 82 HP and 100 TQ.
I am sure it is on here somewhere, but does anyone know offhand what bone stock HP and TQ numbers are for 2013's with the 103TC? Will try and post pics of the dyno sheet later.
2013 Candy Orange RGC, 2009 Electra Glide Std (traded-in),2008 Street Glide (totaled via texting driver), 2002 Wide Glide (traded-in)
flatlander is offline
post #2 of 11 (permalink) Old 08-21-2013, 10:45 AM
Redbeard77's Avatar
Your numbers look about right based on others I've seen with similar setups, but peak numbers don't tell the whole story. If it "runs great and pulls very good" it sounds like you have smooth hp/tq curves, which is what it's all about. Can you post the graph?
Happiness is a warm motorcycle.
Redbeard77 is offline
post #3 of 11 (permalink) Old 08-21-2013, 10:51 AM Thread Starter
flatlander's Avatar
Will try and post it this evening when am home from work.
post #4 of 11 (permalink) Old 08-22-2013, 07:29 AM
Taccone's Avatar
I dyno'd 90hp and 95tq, but again I'm loosing power from my pipes, I'm running the 4.5" CFR's, swapping them out with something with more back press. should gain me prob 5hp and roughtly another 7-10tq.
Taccone is offline
post #5 of 11 (permalink) Old 08-22-2013, 06:29 PM Thread Starter
flatlander's Avatar
Here the printoff of the dyno...my HP was actually 88.3...not the 89 I thought it was.
I know if I went with a different exhaust my numbers would have been better...but like the look and sound of the Rineharts.
post #6 of 11 (permalink) Old 08-22-2013, 10:05 PM
1st post. I just got back from picking up my bike from Alef's. I bought a 2013 road glide ultra from them three weeks ago. I put my 1,000 miles on it and took it in for some upgrades. I purchased V/H true duels, RCXhaust, RC Eclipse A/C, SE 255 cams, TTS tuner, and just had it dyno'd. It shows 88.84 max hp and104.11 max tq. It runs great and seems to have lots of power. I have only had stage one kits on my bikes in the past. I am very pleased and have not stopped smiling.
wildbill66 is offline
post #7 of 11 (permalink) Old 08-28-2013, 10:49 PM
McGruder's Avatar
That's OK, you still have bragging rights on wifey, lol.
2013 RGC - SE Stage 4, V&H Dresser Duals, Rinehart 4", Progressive Monotubes/Ohlins 357, Khromewerks Extend Heritage bars, Daymakers,
J&M 500W XTP amp, 4 Rokker XX speakers, BADDAD lids, Road Tech 665
McGruder is offline
post #8 of 11 (permalink) Old 08-28-2013, 11:55 PM
torqu's Avatar
I would be happy with those numbers. My buddies 12 has same cams plus the harley cnc heads, vance and hines true duels with cfr mufflers and his numbers are like 98hp and 106lbs.
torqu is offline
post #9 of 11 (permalink) Old 08-29-2013, 12:01 PM
NorCal's Avatar
remember your dyno tune is only as good as the operator, I would never have a dealer dyno my bike. I have Cycle Rama 575 cams, S/E Heavy Breather, Dragula and TTS. I dynoed at 97.5hp and 113.65tq.
NorCal is offline
post #10 of 11 (permalink) Old 09-07-2013, 03:58 PM
ERod62's Avatar
+1. After market cams out performs HD's.
Numbers r ok, if runs good and pull strong should be happy.
ERod62 is offline
2013 103 fltrx cvanmete Dyno Results 6 04-18-2015 02:52 PM
2013 FLTRX 103" TMan 555 and Dragos 2/1 Thomas1369 Dyno Results 55 07-04-2013 11:01 PM
2011 RG 103 Engine not only half a 103 Forger Road Glide Specific Discussions 21 12-13-2010 09:12 PM
New Member/FLTRX 103 Sedona Orange Hillglide *General Road Glide Discussions/Pictures 12 11-02-2010 03:56 AM
Factory 103 vs Dealer-installed 103? HD_Shock Road Glide Specific Discussions 18 10-11-2010 03:06 PM
