2010 fltrx 96" - Road Glide Forums
post #1 of 9 (permalink) Old 04-23-2011, 03:54 PM Thread Starter
2010 fltrx 96"
Had a local indie shop do a couple of quick dyno pulls mostly to check my autotune settings, so here it is. I am doing a little adjusting to correct that little dip at 3000 to 3500.
rc_chico is offline
post #2 of 9 (permalink) Old 04-23-2011, 05:24 PM
2 bike Mike's Avatar
Looks like a good run...
2013 Vivid Black Road Glide Custom, 19" contrast cut Agitator, Black V&H with chrome tips, V&H power duals head pipes, 14" apes, black hand levers, and Joker Machine grips, braided cables, Ventilator, J&M Rokker 7.25", Hogtenna, custom painted inner fairing w/airbrushing, LRS shield, Mean City Cycles reworked Sundowner seat, drivers backrest, saddle bag spoilers w/run/brake lights, run/brake tribar.
2 bike Mike is offline
post #3 of 9 (permalink) Old 04-24-2011, 03:36 AM
dirtbag's Avatar
RC, the dyno notes shows a "pro-pipe" in the description, are you running a V&H ProPipe? I have a PCV, ProPipe and Ness STG II A/C, and looking to add the AutoTune. I am interested in your setup and results. The dyno sheet looks great.
2010 FLTRX - THE RED DRAGON
KCCO - CHIVE ON!
dirtbag is offline
post #4 of 9 (permalink) Old 04-24-2011, 01:37 PM Thread Starter
Yes I am running a V&H Pro-pipe (chrome), V&H airfilter PCV with autotune and Andrews 54 cams.
rc_chico is offline
post #5 of 9 (permalink) Old 04-24-2011, 10:26 PM
allofus81's Avatar
I hope your tuner is correcting the really really really lean afrs. That is one of the worst ones Ive ever seen. But maybe it has already corrected it. Be careful.
allofus81 is offline
post #6 of 9 (permalink) Old 04-25-2011, 12:39 AM
dirtbag's Avatar
What is the correct AFR for an air-cooled, gasoline combustion engine?
KCCO - CHIVE ON!
dirtbag is offline
post #7 of 9 (permalink) Old 04-25-2011, 12:40 AM
dirtbag's Avatar
Nice, I'd like to do a cam and the AutoTune, in the near future. Although, I've been saying that for awhile.
KCCO - CHIVE ON!
dirtbag is offline
post #8 of 9 (permalink) Old 04-25-2011, 06:01 AM
Peewee's Avatar
I belive it is 13.6 If you look at your bottom chart, your A/F line should be right on top of the dotted line
"Know Thyself"
Peewee is offline
post #9 of 9 (permalink) Old 04-25-2011, 05:46 PM Thread Starter
Under full throttle it should be 13.2 to 1 for best power. At part throttle cruise for best economy, around 14 to 14.5 to 1. Most tuners I have seen set it at 13.2 to 1 at all throttle openings. You get great power and drivabilty, and maybe 30 MPG.
rc_chico is offline
Need map for 2010, 96", v&h dresser duals, rush 3.5", 2" baffle ilmanzo31 Map Section 3 07-28-2016 03:52 PM
96 ci 50K miles 2010 FLTRX big o Engine Related 4 02-15-2016 08:17 AM
Looking to Stage 2 2010 fltrx 96" mrmoto95 Engine Related 12 02-17-2014 06:28 AM
2010 fltrx 96" RGKen Dyno Results 6 01-29-2013 06:18 AM
