Front end/fairing rattle? - Road Glide Forums
Companies We Can Recommended! List Companies here that we have verified and we have done business with. List their Web site and phone number if you have it. LIST ONLY COMPANIES YOU HAVE USED AND ARE HAPPY WITH!
post #1 of 13 (permalink) Old 03-31-2015, 05:23 PM Thread Starter
I have a 2011 RG ultra, does anyone else have a rattle in the front end, I do know if it's the forks rebounding/ dampeners shot out or what, any help is appreciated.
Porkroll is offline
post #2 of 13 (permalink) Old 03-31-2015, 06:45 PM
Bandit 7's Avatar
Could possibly be the brake pads you are hearing. When are you hearing it? When it starts doing it lightly pull in on front brake and see if it goes away.
Bandit 7 is online now
post #3 of 13 (permalink) Old 03-31-2015, 06:53 PM
JacktheBagger's Avatar
First thought is wheel bearings
JtB
2011 Ultra
JacktheBagger is offline
post #4 of 13 (permalink) Old 04-01-2015, 09:41 AM
Pull the outer fairing and look inside the outer for rub marks, rub marks is common near the top center area of the outer fairing where the radio bracket is.
Also look for loose electrical plugs that may be hitting the inside of the fairing and secure them if needed.
post #5 of 13 (permalink) Old 04-01-2015, 09:53 AM
griswold's Avatar
Have you checked all the bolts around your brake calipers and fender?
2010 FLTRX, 2003 FXDX, 1983 XLH1000, 1975 FLH
griswold is offline
post #6 of 13 (permalink) Old 04-01-2015, 09:58 AM
PGR
PGR's Avatar
Welcome to the forum. Grab some wrenches and check all your fasteners. My 05 windshield used to rattle during deceleration.
I notified an administrator to have this moved to the correct forum for the subject.
Ron..........................
PGR is offline
post #7 of 13 (permalink) Old 04-01-2015, 10:28 AM
mouser58's Avatar
Might sound ridiculous, but is there anything in you fairing compartments that might rattle??? I put padding in all my compartmentsand it went away.. mine sounded really bad and realized the problem after I took everything out one day..
Bigfoot likes this.
2012 Ultra...Stage 1...Vance & Hines Power Duals,SE Night Sticks, V&H Digital, Stock air box with larger fliter..
mouser58 is offline
post #8 of 13 (permalink) Old 04-01-2015, 10:31 AM
scaryuncle's Avatar
Headlight bezel?
2011 Ultra 1989 FXRS
scaryuncle is offline
post #9 of 13 (permalink) Old 04-01-2015, 08:16 PM Thread Starter
Thanks for the help, I'll try to run it down
Porkroll is offline
post #10 of 13 (permalink) Old 04-02-2015, 07:41 PM
GlideShark's Avatar
I had a bad rattle, turned out to be this---
GlideShark is offline
Rattle in fairing hawwk Tech Area 6 07-16-2017 07:39 PM
Rattle / Clanking Right Side Bottom End wevsspot Troubleshooting for Road Glides 21 06-03-2017 05:07 AM
Tin Can Rattle front Right of 110 ccallahan Engine Related 18 02-17-2014 07:04 AM
Inner Fairing Rattle FloridaFLTRU Troubleshooting for Road Glides 5 10-19-2013 03:14 PM
Annoying clunk/rattle over bumps from front end GizmoGlide *General Road Glide Discussions/Pictures 17 04-01-2010 03:15 PM
