Replace 255's in 2013 RGU - Road Glide Forums
post #1 of 5 (permalink) Old 12-23-2013, 08:13 PM Thread Starter
I bought a 2013 Road Glide Ultra and let the dealer do my upgrades. (enough said?)
They installed a fatcat 2-1, S/E-A/C, S/E tuner, and 255 cams. Dyno tuned and I
don't really like it. I was told that it needs a good tune.
If I am going to do that then I think a better cam would be needed also.
Mr. Wood said a 222 would work great for 2 up.
I would like to know which cam would give me the best performance? 50* 2-up
The 255's do fine then fall off quick.
Any and all advice needed.
Thank you
bfuller14 is offline
post #2 of 5 (permalink) Old 12-24-2013, 08:38 AM
r0de_runr's Avatar
I like my Andrews 57H setup.
The other one is my SE255 stage two done by the dealer.
Both bikes dyno tuned in the winter time by Ed Dahir.
r0de_runr is offline
post #3 of 5 (permalink) Old 12-24-2013, 10:49 AM
Thank you
If the dealer did a dyno tune you shoudn't need a good tune. Sound to me that the dealer did a basic remap and charged you for a dyno tune. My bike with the 255 cam and the same mods except I had a true dual exhaust produced 107 lbs of torque and it would be hard to find a aftermarket cam that would produce equal to or more torque then that with typical mods. A good dyno tune depends on the experience/knowlege of the person doing the tune. At $500 a dyno tune the HD dealer wants to get your bike in and out of the dyno as fast as they can so they can get the next bike in.
post #4 of 5 (permalink) Old 12-24-2013, 03:48 PM Thread Starter
Thank you all.
Ironmark that sounds like what they did. I was told that I needed
a good tune by a good tech.
post #5 of 5 (permalink) Old 12-24-2013, 10:47 PM
Be careful geting a dyno tune from a independent shop too. Some Indys don't work well with some tuners. Some indys can't tune a SERT and most HD dealers don't tune anything but a SERT, sometimes it is because of the software/hardware or lack of knowlege of the tuner you are using.
Replace the inner front fairing on a 2016 RGU DigitalGlide Do-IT-Yourself 4 03-25-2016 03:44 AM
CVO 255 cams (AKA SE-255) cams pat123 Parts for Sale 3 07-26-2013 08:58 AM
Can standard male end pegs be used to replace stock passenger pegs(2013) 13-FLTRX Equipment-RG 3 01-09-2013 02:51 PM
Radio suggestions to replace HK? Sincecrazy Audio 34 01-27-2012 06:14 PM
Sirius Sportster - fail - replace with? Sincecrazy Aftermarket Accessories 6 09-24-2010 10:29 AM
