Birth of the FrankenGlide :-) - Road Glide Forums
post #1 of 65 (permalink) Old 04-10-2014, 03:41 PM Thread Starter
Andreas's Avatar
OK, all purists: stop reading this.
Over the years I had collected a large amount of Harley parts and every time I looked at them I thought the same thing - I should build something cool from that stuff sometime. I had enough to build a bike and a
half.... So I decided to piece together a Road Glide style bike. Not that I really needed another bike and it wasn't exactly the right time to throw money at yet another project. The plan that started to develop in
my brain wasn't based on reasonable things either so, in short - the perfect project. :-)
I had this 1981 FLT Harley frame sitting in the garage for years. It was straight in the front section but had a bad rear section. Since I have a title to it I wanted to save it and build a new bike from it.
I fished a 2010 touring frame out of the trash container at a friendly H-D dealership. The neck had been cut off and sent to the MoCo so they could send a new frame with the same VIN.
The question was if I could create one good frame from the parts I had. I took measurements and compared angles etc. and came to the conclusion that those frames haven't changed at all regarding their
geometry and the main mounting points! The differences are in fact so small that a lot of things are interchangeable with easy modifications. So I went for it. I cut off the neck of the 1981 frame and the 2010
frame was tacked to a perfectly level welding table to make sure it wouldn't move. Then cuts were made to the down tubes so the 1981 down tubes would slide in. We built a jig to make sure the frame parts lined up properly. After spending a good hour on adjusting things everything looked good and we tacked the frame sections together.
The outer diameter of the 1981 down tubes coincides with the inner diameter of the 2010 down tubes so the old section fit right into the new. The backbone square tube is the same size. Only the rolled edges are a little more pronounced. Easy to blend but that portion is covered by the tank anyway.
1981 FLT FrankenGlide
2003 FLHT Jim's 131cui, SE 6-speed
1980 FXWG
Andreas is offline
post #2 of 65 (permalink) Old 04-10-2014, 03:49 PM Thread Starter
Andreas's Avatar
The neck needed some minor modification to accommodate a 2003 lock set I had so I replaced the old fork lock tab with one I had cut off a 2006 neck.
The tank mount didn't look too good so that got beefed up:
More material added to the frame tubes and a little blending....
1980 FXWG
Andreas is offline
post #3 of 65 (permalink) Old 04-10-2014, 03:52 PM
RebelGlide's Avatar
wow...creative build
2013 Road Glide Custom..Big Blue Pearl
D&D fat cat, Stage 1 AC, HD Tuner, So Cal HID, 12" Malo's, 8" KW and 12" WV, and other doodads.
RebelGlide is offline
post #4 of 65 (permalink) Old 04-10-2014, 03:53 PM Thread Starter
Andreas's Avatar
The frame is all done and sand blasted:
To me a freshly powder coated frame is a thing of beauty!
1980 FXWG
Andreas is offline
post #5 of 65 (permalink) Old 04-10-2014, 03:56 PM
The Volusianator's Avatar
This thread scares the shit outta me!
The Volusianator is offline
post #6 of 65 (permalink) Old 04-10-2014, 04:01 PM
DED HD's Avatar
Cant wait to watch your progress! I have the same dream too, where i build a bike out of spare parts laying around.
Thanks for sharing.
'10 Red Custom:
DED HD is offline
post #7 of 65 (permalink) Old 04-10-2014, 04:03 PM
HD4me's Avatar
I have always envied people that can work metal into things of beauty. Keep up the posts...
2011 FLTRUSE
1999 FLHRCI
HD4me is offline
post #8 of 65 (permalink) Old 04-10-2014, 04:04 PM Thread Starter
Andreas's Avatar
So this '81, '06, '09 and 2010 frame was ready for motor and transmission. I had a complete setup from a 2009 salvage bike with paperwork and a ton of other important parts. It was very filthy but only had
9,000 miles on it. Cleaned up very nice and installation was unconventional but very efficient:
I laid the whole thing on it's right side and lowered the frame over it. Took a little wiggling around but after just a few minutes everything was lined up and loosely bolted together:
Flipped it back up with the swing arm in place. Making progress!
1980 FXWG
Andreas is offline
post #9 of 65 (permalink) Old 04-10-2014, 04:12 PM
Stray Mutt's Avatar
I don't suppose that's a typo in the sig line, is it? 131 cubic inches??
Stray Mutt is offline
post #10 of 65 (permalink) Old 04-10-2014, 04:14 PM
Great job. Going to be nice I'm sure. Old Sportster trick laying the motor on the side and laying the frame over it.
Zach
07 Road Glide
ZachT is offline
Frankenglide TracyB Road Glide Builds-Document your builds HERE --NEW 172 03-27-2014 02:40 PM
