05 Road Glide motor swap - Road Glide Forums
post #1 of 5 (permalink) Old 09-11-2014, 02:51 AM Thread Starter
Im trying to find out if a 08 street glide 96" motor and transmission will fit my 05 frame. Ive seen a few post but none say if they actually was able to get it done or not.
V-style is offline
post #2 of 5 (permalink) Old 09-11-2014, 10:29 AM
The basic frame is the same from 98 to 08 except for the top motor mount on the 08 frame. But I never did the swap so there may be some small discrepancies that need to be dealt with.
If you already have the 96 inch with the 6 speed trans and you are doing the work yourself you should give it a try.
post #3 of 5 (permalink) Old 09-11-2014, 11:08 PM
RoadGlideRider's Avatar
Yes, 96" motor/Transmission from 2006 to 2008 will fit your frame. But you must have the correct transmission to go with the correct motor. The 96" motor must have the 6 Speed Transmission. And the 88" motor must have the 5 Speed Transmission.
The 5 Speed will not mate up correctly to the 96" motor.
RoadGlideRider is offline
post #4 of 5 (permalink) Old 09-11-2014, 11:38 PM
torqu's Avatar
Correct. Older motor oil lines are ran externally, and the newer engines and trans are internal.
torqu is offline
post #5 of 5 (permalink) Old 09-15-2014, 08:41 PM
I just swapped my 08 out and dropped a 12 motor in. If you want a few pics of 08. Let me know
milkman48 is offline
Just a little motor swap..... Gunslinger Road Glide Builds-Document your builds HERE --NEW 31 07-14-2015 01:33 PM
05 Motor work V-style Engine Related 3 09-13-2014 10:13 AM
2012 Street Glide slip ons on a 05 Road Glide? cfbeauvais Intake and Exhaust 1 05-04-2013 09:02 AM
Lower Fairing doors - 58681-05 & 58679-05 akawolf Sold 1 03-10-2013 11:25 AM
05 electra glide tour pak on 12 road glide custom W_D_R Equipment-RG 2 08-08-2012 10:31 AM
