From the Ground up - Road Glide Forums
 3Likes
  • 1 Post By Jacobus
  • 2 Post By Jacobus
post #1 of 7 (permalink) Old 12-11-2018, 11:14 AM Thread Starter
Jacobus's Avatar
From the Ground up
Last Updated (DEC 11, 2018)
Sup fellas, I Started back in July of 2018, I have a very limited budget. I know there's cheaper ways to get on a RG, but Im in it for the long haul. I like to build bikes. I wanted somewhere to post my progress and have a place for people to catch my mistakes.
Here's the Frame Completely stripped down, and started cleaning it. It's going to be a 2005 RG, Carbed 88ci, with a SS larger cam,
74craig likes this.
Jacobus is offline
post #2 of 7 (permalink) Old 12-11-2018, 11:31 AM Thread Starter
Jacobus's Avatar
Swing Arm
AUG 6th, Got the Swing Arm and 26th got the shock oil replaced, I used a vacu pump to get the old oil out. Most of it just drained out. I used negative pressure to pull new oil back in. Also installed Belt, axle, Caliper and chrome fender struts.
I decided to go chrome instead of blacked out, The SV650 I built last year was mostly blacked out. So I'm kinda bored of it. I've always dug chrome on Harleys.
Screenshot_20181211-111830_Gallery-810x1440 by [url=https://www.flickr.com/photos/[email protected]/]
Jacobus is offline
post #3 of 7 (permalink) Old 12-11-2018, 11:39 AM Thread Starter
Jacobus's Avatar
Trans
Aug 31st, mounted the transmission, and wrapped the belt around the front pulley and axel. Just waiting on a rear wheel.
Screenshot_20181211-111712_Gallery-810x1440 by , on Flickr
Jacobus is offline
post #4 of 7 (permalink) Old 12-11-2018, 11:51 AM Thread Starter
Jacobus's Avatar
Spoke Rims or Cast
Here's where some learning went on. I thought I wanted spoked rims on my build. They just look classic and I liked them. However after struggling with the tube only to get it punctured. I decided I couldn't patch this on the side of the road and bought a 18" wheel of a street glide.
Having to measure and measuring some more, because this wheel has an anti lock break bearing in it. I shaved down the spacers to fit two new double row bearings, so It would fit using the drill bit method that's in the OEM manual. If I remember right I made the narrow spacer .66 and the wide .776. The .66 on the right side could have been a hair wider. I would start with .776 on both sides then go from there
I didnt use a bearing puller to get the antilock bearing out. I welded a washer on the old bearings and punched them out with a steel rod. Then Gave a one to each of my kids.
2018-12-11_11-44-49 by
Screenshot_20181211-112354_Gallery-810x1440 by
Jacobus is offline
post #5 of 7 (permalink) Old 12-11-2018, 12:02 PM Thread Starter
Jacobus's Avatar
Rolling Chassis
Finally caught up to date. 12" apes came in. I'm 6,1 and this is what I found to be the most comfortable. Its actually putting my hands lower than in my work truck, and I have to take long trips on that. Risers, calipers and stainless steel lines.
Also mounted the rear Tire. A new bottle of Windex not the cheap knock off made this a lot easier. These wheels came with tires but I put a tire with less wear on the back. I'll probably get used to the bike, do a burnout and replace them with new ones. Mounted the Rear Pulley, and Disc Brakes
20181207_151724-600x800 by , on Flickr
20181207_164615-800x600 by , on Flickr
74craig and RoadglideinMO like this.
Jacobus is offline
post #6 of 7 (permalink) Old 12-12-2018, 09:47 AM
74craig's Avatar
Looking good!!!
74craig is offline
post #7 of 7 (permalink) Old 12-12-2018, 10:38 AM
Tourhog's Avatar
Nice. Keep posting your progress.
2013 RGU BBP
Tourhog is offline
Building a 117 from the ground up. DragoBikeWorks Engine Related 66 10-03-2012 09:16 PM
Ground zero? crazyredneck Road Trip Discussions/Stories/Pictures 4 09-12-2012 07:09 AM
Ground wire? Willy_B Audio 2 05-16-2012 11:08 PM
Ground Strap. Misplaced Troubleshooting for Road Glides 2 04-14-2012 11:59 AM
Putting the Glide on the Ground??? jbrawkus *General Road Glide Discussions/Pictures 10 01-11-2011 08:30 PM
