Paint entire bike with Blitz Black Questions - Road Glide Forums
post #1 of 20 (permalink) Old 12-03-2013, 05:11 PM Thread Starter
I did a search in this forum to read up on the JDBB. I am converting my 2005 FLHTCI to a Roadglide. It is coming along pretty well. My bike is two tone, chopper blue and silver. I thought I could cheap out and paint the fairing and new front fender chopper blue. I'm kinda not liking that too much. First off, a friend was helping me out and the paint is not a dead on match. Second, it kinda looks funny with the silver blob on the side of the tank. I was planning on saving up for a nicer paint job next winter, but don't want the bike to look freaky until then. So my choices now are:
1. Ride it like it is for a year.
2. Paint the bike Blitz Black or some other hotrod type black.
3. Paint the tank to match the fairing.
I'm leaning towards number 2. Paint the bike. I have a big 80gal air compressor and reasonably clean air. I have a Devilbiss Finishline paint gun. Is it really as simple as scuffing the paint, sanding down the two tone areas and rolling with Blitz Black, or should I seal the whole thing first? How much paint is too much paint to have on the fairing? I started off as Red, is now blue and will go to one more color if I change the color.
Here is a pic of the partially assembled bike.
Thanks for the help!
DOM
MCVDOM is offline
post #2 of 20 (permalink) Old 12-03-2013, 05:21 PM
Ohiobellboy's Avatar
Paint the rest of it to match what you've done to the front. Then again, I'm partial to blue as I own 3 blue trucks. lol
A.K.A OBB
Ohiobellboy is offline
post #3 of 20 (permalink) Old 12-03-2013, 05:38 PM Thread Starter
Oh, I forgot to mention that due to RG conversion money is really tight!
MCVDOM is offline
post #4 of 20 (permalink) Old 12-03-2013, 07:01 PM
Pistokcha's Avatar
Paint the tank Blue to match the fairing.....gotta be the least expensive option at this point. Ride that blue machine until you have enough $$$ to do a custom paint job that suits you better.
2011 FLTRX Sedona Orange
Pistokcha is offline
post #5 of 20 (permalink) Old 12-03-2013, 07:13 PM
Shark of the Month August 13
SIC_26's Avatar
Agreed! Plus it looks like a really good blue!! (though it doesn't match at all)
Paint everything else the blue and rock it for a while
My concern with painting everything with that tractor paint would be, how "stable" is it as a substrate when you would paint over it in the future, I don't know I don't know how (or even if) it would react to the thinners in a "real" paint job. Just some thing to think about or maybe look into
SIC_26 is offline
post #6 of 20 (permalink) Old 12-03-2013, 07:49 PM
Transplant's Avatar
Put it together and ride it until you can paint it the way you want.
Transplant is offline
post #7 of 20 (permalink) Old 12-03-2013, 08:01 PM
Triplej's Avatar
+2, or it it 3??
Triplej is offline
post #8 of 20 (permalink) Old 12-03-2013, 08:14 PM
RoadHawg's Avatar
If you do decide to go all black use the SEM "Hotrod Flats" catalyzed low gloss black with a good epoxy primer under it so your future jobs will have a fighting chance of not blowing up on you wrinkling as they go over tractor enamel.
If you want that chopper blue to match perfectly use PPG Chopper Blue Pearl B/C 908588 base coat and clear. This isn't a tricoat color and it's quite easy to shoot.
Mikes Hawg Paint, Camino, CA.
RoadHawg is offline
post #9 of 20 (permalink) Old 12-03-2013, 08:37 PM Thread Starter
Thanks for the help fellers. So assuming I was going to go with the SEM Hotrod paint, what primer would go best with that? When should I start worry about material thickness? How many coats is too many?
So wash with soap and water, then wax and grease, then scuff, epoxy primer, finally the hot rod black?
MCVDOM is offline
post #10 of 20 (permalink) Old 12-03-2013, 09:16 PM
RoadHawg's Avatar
PPG DP90LF black epoxy primer is the ultimate primer/sealer, two medium coats is all you need.
Film build issues depend a lot on how the previous jobs were prepped/shot, I've seen factory two tone jobs where they didn't scuff the previous coat and it would peel just by putting tape on it. Also just had a factory CVO job in for repair and you could see where one bag got ran back thru the paint line four different times! Sanded down it looked like rings on a tree.
RoadHawg is offline
Painted windshield "Blitz Black" 90b4032 Windshields 4 01-19-2015 08:44 PM
JD Blitz Black Paint Rkfltrx Paint & Bodywork Section 1 10-11-2013 01:41 PM
Blitz Black after Plasti-Dip LAWLESS23 Paint & Bodywork Section 9 07-26-2013 05:31 PM
John Deere Blitz Black yamahoe72 Paint & Bodywork Section 4 10-08-2012 12:11 PM
Video on how to match denim black with blitz black CHAINSAW Paint & Bodywork Section 14 06-02-2012 12:00 PM
