muffler? - Road Glide Forums
post #1 of 3 (permalink) Old 12-15-2013, 09:17 AM Thread Starter
StGhost's Avatar
muffler?
Will powder coating last on a muffler?
StGhost is offline
post #2 of 3 (permalink) Old 12-15-2013, 10:03 AM
RoadGlideGary's Avatar
Your PC shop should answer that because you won't want to leave them off with them if the answer is no. High Temp Ceramic PC should hold if the prep, application and remainder of work is done properly.
05' SuperGlideCustom - sold
RoadGlideGary is offline
post #3 of 3 (permalink) Old 12-15-2013, 12:07 PM
faststan's Avatar
I got some rust on mine after running thru some salt water. I had them ceramic coated. They first sand blast part to remove original surface then ceramic coat. All Rush pipes are ceramic coated. Also, I believe Drago's are ceramic coated.
11 FLTRU 103 Red Hot Sunglow
faststan is offline
Swapping D&D Louvered baffle muffler out for the wrapped perforated muffler question bigshaqa Intake and Exhaust 6 03-25-2016 02:23 PM
Dragula Chrome Muffler (Only the Muffler) for Sale Tytanium Parts for Sale 8 08-30-2014 07:39 PM
screamin eagle nightstick 2-into-1 slip on muffler plumcrazeman Intake and Exhaust 64 04-18-2011 02:54 AM
Carriage Works Slip On Muffler TexRedGlide Intake and Exhaust 4 12-08-2009 04:22 PM
Carriage Works Muffler zzmellio Videos 4 11-13-2009 07:08 PM
