Filling Tour Pak Holes - Road Glide Forums
post #1 of 4 (permalink) Old 02-15-2014, 09:47 AM Thread Starter
I've had a tour pak for a couple of years and decided to replace the original backrest pad with a C&C Banana pad. This along with using a hidden antenna now leave several visible holes. I'm wanting to fill the holes and repaint the pak. I've read several post here and on other forums regarding this. It seems that there are lots of options if you know what type of material the pak is - I have no idea - plastic to me is all the same. I've read that "bondo" will not hold. I did find this product on another site: http://www.plast-aid.com/ . Has anyone used this or another product they can recommend?
Thanks
gfyoung3 is offline
post #2 of 4 (permalink) Old 02-15-2014, 09:55 AM
I've never done that, but I would suggest a auto paint supply store. Good luck with your project.
2011 FLTRX 103 Sedona Orange
Hillglide is offline
post #3 of 4 (permalink) Old 02-15-2014, 11:18 AM
RoadHawg's Avatar
Yep, your local auto body supply store will set you up with the correct repair material in a smaller single use applicator.
If the inside of the lid is gray it is the fiberglass based SMC material, if it is black it is PPO/GTX (not ABS!)
Each one takes a totally different repair process
Btw, I notice that the all new 2014 tourpac bottom half is made of the older pre 2004 GTX fiberglass, the lid is still the plastic GTX
Mikes Hawg Paint, Camino, CA.
RoadHawg is offline
post #4 of 4 (permalink) Old 02-15-2014, 11:40 AM Thread Starter
Mine is black so I guess it is GTX. Thanks
gfyoung3 is offline
Covering unused holes on a knock-off Tour Pak HighwayStar General Off-Topic Discussions 5 03-19-2018 05:50 PM
Runs poorly after filling up with gas PAhumbug Troubleshooting for Road Glides 9 07-09-2014 04:34 PM
Filling King Tour Pak Backrest Holes 93-331-29psi Do-IT-Yourself 4 05-26-2014 10:36 AM
Filling Holes on Tour-Pak from Antenna Mount hoser6868 *General Road Glide Discussions/Pictures 6 02-23-2012 10:21 PM
Filling hole for mirror. fosterp Controls & Handlebars 8 01-28-2012 10:56 AM
