Painted inner fairing - Road Glide Forums
post #1 of 16 (permalink) Old 03-01-2014, 10:04 AM Thread Starter
Brianu1's Avatar
I've decided to have my inner fairing painted to match. However, I am not doing the Harley painted inner because of the cost and didn't need an extra inner fairing laying around, so I'm just having mine painted from the dealer paint company. They send it out to a painter they work with. Charge $400 vs. $1000+ for the HD. That doesn't include labor to remove and re-install. Any cons going with a painter vs. HD inner fairing? I would think a painter will do just as good of a job, or the HD dealer wouldn't offer it. Hope it looks as good,
FLTRX, Black Edge Cut Blade wheels & rotors, RSD Seat, TW-777, V&H Power Duals w/ CFR's, Daymakers, SE A/C, PV tuner, Soundz Customz LV-4 audio, Klockwerks Flare 12" smoke, CD LED's, Progressive shocks, & lots of others...
Brianu1 is offline
post #2 of 16 (permalink) Old 03-01-2014, 10:17 AM
The inner fairing removal/installation is a easy DYI so give it a try.
Check out http://www.fatbaggers.com for a painted fairing.
Fat Baggers sells painted inner fairings for $500 with a core exchange. You order the inner painted in your color than when you get the inner you swap out the inner and send your inner back to them. The big advantage is you get a factory paint job with no flaws and you only have around 5 to 6 hours of down time.
post #3 of 16 (permalink) Old 03-01-2014, 10:54 AM
mjsdouble's Avatar
I would save the money vs buying a painter inner from HD. I had mine done at an independent painter. They charged me $300 and did the removal and install. They did have to paint it twice. Claimed blistering on the 1st try lol. Wanting to know what foreign material was on it. So they ended up having it a few extra days. I really like the suggestion from ironmark and would highly consider that option. I had the outer off just before painting the inner. I think even I can have success removing the inner. Good luck with your decision and you'll love the new look.
mjsdouble is offline
post #4 of 16 (permalink) Old 03-01-2014, 01:43 PM
Lucky D's Avatar
Don't forget to factor in that shipping an inner fairing can cost as much as $200 due to the size of the box used to ship it.
... Chrome?? We donneeedno stiinnkinng chrome.
Lucky D is offline
post #5 of 16 (permalink) Old 03-01-2014, 07:30 PM
I don't think the shipping cost would be that much!
Fat Baggers will figure the return shipping in the cost and provide the return shipping label and since companies pay a lot less in shipping then a individual the cost is not too bad.
When you do buy a product you will either have to pay sales tax or shipping and in most cases the cost between the two would be pretty close.
Having the fairing done by a local painter you would only have to pay sales tax on the product and not the labor in most cases.
The biggest problem with having a local painter doing the job is turn around time along with the quality of the paint job. If you are not riding because you are waiting for spring then the turnaround time is not an issue.
post #6 of 16 (permalink) Old 03-02-2014, 04:03 AM
Kevin0032's Avatar
I just had mine done from a painter used by HD stores in this area...250$...he removed and reinstalled.....did a great job....
Thanks,
Kevin
2013 Road Glide Custom
Kevin0032 is offline
post #7 of 16 (permalink) Old 03-02-2014, 05:49 AM
HellInABucket's Avatar
If any of you are in Florida I'm sure Paul is in Daytona, he does an AMAZING job. He did mine, and it was more expensive because of shipping. My Midnight Pearl inner looks tremendous and no signs of quality problems whatsoever.
https://www.facebook.com/PaintedHarleyFairings.
Shipping cost can eat you alive on Road Glide fairings.
2020 FLTRK
Roll away the dew...
HellInABucket is offline
post #8 of 16 (permalink) Old 03-02-2014, 07:07 AM
RGKen's Avatar
+1 on Paul ^^^^
If you plan to come down for Bikeweek he will hook you up. Just message him on FB and work out the details. I also know that a lot of guys in different parts of the country use him because they still saved money having him ship the inner. It's another option to look into and he takes your old fairing off your hands.
2018 FLTRXS
RGKen is offline
post #9 of 16 (permalink) Old 03-02-2014, 10:31 AM
Shark of the Month October 13
Location: Was northern Maine, now gulf coast of Florida
Since your bike is black, the local painter should do just fine with your inner. If you had any of the pearls or candy paints you'd want to see evidence of his previous work with those paints to check color match. Make sure you've never sprayed the inner with any cleaner/shine agent that had silcone in it. It's nearly impossible to get all the silicone out and your new paint job will likely not hold up well. I'm not a painter, just collective knowledge learned on this site over the years.
“Life should not be a journey to the grave with the intention of arriving safely in a pretty and well-preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming “Wow! What a Ride!” - HST
Uncle Fuzzy is online now
post #10 of 16 (permalink) Old 03-02-2014, 10:49 AM
Originally Posted by RGKen View Post
+1 om Paul ^^^^
A friend an I installed mine locally, again Paul's work was *killer* on my Midnight Pearl, however, I'm told that watching him replace these is amazing, I guess he can knock out a bat wing in 45 minutes, probably a bit more on a fugly.
2020 FLTRK
Painted inner fairing colors? Opinion DARRTILLM Aftermarket Accessories 16 01-21-2011 08:27 PM
Need some painted inner fairing pics TracyB *General Road Glide Discussions/Pictures 25 01-15-2011 05:55 PM
Inner Fairing Painted & More Shrug *General Road Glide Discussions/Pictures 21 07-14-2010 09:09 PM
Painted Inner Fairing RWB427 *General Road Glide Discussions/Pictures 30 05-23-2010 08:14 PM
Want the Painted inner fairing, what year and model? RoadGlideBlues *General Road Glide Discussions/Pictures 9 10-23-2009 07:54 AM
