Need to touch up the paint on the cylinder heads - Road Glide Forums
post #1 of 5 (permalink) Old 03-21-2014, 11:50 AM Thread Starter
Just had my cylinder heads reconditioned and there are a few places where the paint is coming off mostly around the exhaust ports. I don't really need to paint the complete head I just need to do some touch up. Would the HD engine paint work well with the touch up or should I just use high temp paint such as barbeque grill paint?
post #2 of 5 (permalink) Old 03-21-2014, 04:31 PM
Banned
use the HD paint,wont be able to tell where you touched it up,perfect match
hotrod is offline
post #3 of 5 (permalink) Old 03-21-2014, 08:12 PM
NorCal's Avatar
if you are referring to this, it matches very well
http://www.harley-davidson.com/store...p-paint-bottle
NorCal is offline
post #4 of 5 (permalink) Old 03-22-2014, 11:59 AM Thread Starter
I have the HD engine paint I just don't know on how heat resistant it is. The rear cylinder head by the exhaust port is the only place the paint is coming off which makes sense because that is the hottest area of the engine.
post #5 of 5 (permalink) Old 03-22-2014, 01:53 PM
GlideShark's Avatar
The engine brightener paint works and heat resistant. I have also used VHT engine paint for touch ups-- close to cylinder heads but usually for when my pipes hit the ground. Not 100% match but you really have to look.
Sent from Motorcycle.com App
GlideShark is offline
Any tips on using harley touch up paint. vizcarmb Paint & Bodywork Section 4 06-01-2013 06:10 PM
Touch Up Paint Do's And Don't Fahred Paint & Bodywork Section 5 08-24-2012 03:52 PM
Touch-up Paint: Black Pearl AND Clearcoat Savoir-Faire Classifieds Archive (3 months old+) 0 11-20-2011 04:09 PM
Touch up paint application dspencer Paint & Bodywork Section 4 08-24-2011 12:33 PM
