Clutch cable scratching paint on speedo! - Road Glide Forums
post #1 of 10 (permalink) Old 04-05-2014, 07:02 PM Thread Starter
Brianu1's Avatar
I just had my inner fairing painted, and the clutch cable is rubbing and scratching the speedo housing. The cheap plastic cable holder doesn't work and so my new paint job Is scratched. Any suggestions on keeping the cable off the paint? Thanks.
FLTRX, Black Edge Cut Blade wheels & rotors, RSD Seat, TW-777, V&H Power Duals w/ CFR's, Daymakers, SE A/C, PV tuner, Soundz Customz LV-4 audio, Klockwerks Flare 12" smoke, CD LED's, Progressive shocks, & lots of others...
Brianu1 is offline
post #2 of 10 (permalink) Old 04-05-2014, 07:08 PM
pacfan1967's Avatar
Clutch cable clamp. I got this one from J and P.
http://www.jpcycles.com/product/5200045
Just make sure you get the correct one for your bar diameter.
Ride safe, Gary
pacfan1967 is offline
post #3 of 10 (permalink) Old 04-05-2014, 07:15 PM Thread Starter
Brianu1's Avatar
I have one of those already installed and doesn't help up top. When you turn the bars, the cable rubs, especially to the left. Maybe I don't have the clamp installed correctly?
Brianu1 is offline
post #4 of 10 (permalink) Old 04-05-2014, 07:16 PM
pacfan1967's Avatar
Maybe. Mine doesn't rub anywhere. Try loosening it up and repositioning it.
Ride safe, Gary
post #5 of 10 (permalink) Old 04-05-2014, 07:42 PM Thread Starter
Brianu1's Avatar
A couple questions. What year is your bike? Is your cable clamp above the rubber cover that looks like a shock cover, or beneath it. Might is down low beneath the rubber cover. I put it where I cut the zip tie HD had tied the cable to the frame. Thanks.
Brianu1 is offline
post #6 of 10 (permalink) Old 04-05-2014, 08:49 PM
I don't have my inner painted but, if your clamp keeps pulling out of it's hole & doesn't have a broken tab, just take it out & turn it around. That's what I did & it stayed in or buy a new clamp. item 18 #70385-01.
http://partsfinder.onlinemicrofiche....TER-ASSEMBLIES You might try some clear protective tape. Good Luck.
Go to Speedo & Tach assy.
2011 FLTRX 103 Sedona Orange
Hillglide is offline
post #7 of 10 (permalink) Old 04-05-2014, 09:07 PM
I dont have it painted but like mentioned before turn the plastic clip around. I had to flip the clip and been using it that way for 2 years. No rubbing either
post #8 of 10 (permalink) Old 04-05-2014, 10:47 PM
rageglide's Avatar
You need something like this, granted this is stupid expensive, but it's an example.
http://www.pro-one.com/Speedo_Cable_...t_p/500720.htm
Or ditch that little POS clip and re-route the cable similar to a Road King if you have apes.
2012 fltrx
rageglide is offline
post #9 of 10 (permalink) Old 04-06-2014, 07:19 AM
bucketlisthd's Avatar
My clutch cable wants to migrate away from my speedo housing. I used a zip tie to hold it. In your case, you could make a stand off by running a zip tie thru a washer on the inside of the speedo, and then both sides of the tie thru a black fuel line cut to length, and around the cable. I bet it would blend in. I used that method to temporarily mount my lowers. It's been 2 years now, and I never did fix them.
'15 Roadglide Special
'87 FXR 100"
'79 Goldwing cafe
bucketlisthd is online now
post #10 of 10 (permalink) Old 04-06-2014, 10:08 AM
I just bought a good quality black (plastic?) coated clamp from the local hardware store that was a larger diameter than the cable and attached it using the existing screw on the speedo cover. The cable can move freely and it doesn't rub!
seahoch is offline
Changed clutch cable to +6 cable...clutch does not appear to engage backwaterdogs Troubleshooting for Road Glides 4 05-20-2017 08:09 PM
Need Help-Clutch Cable Lever Change-Tight Cable SNemet Controls & Handlebars 6 04-28-2016 05:42 PM
Tour Pak install without scratching paint? Irish22 Equipment-RG 11 12-16-2013 08:51 PM
Inseam scratching tank Road08Glide Paint & Bodywork Section 23 04-11-2013 11:33 PM
CD Player Scratching CDs? BillyBob Audio 6 03-14-2011 06:15 PM
