Klock Werks fender???? - Road Glide Forums
post #1 of 4 (permalink) Old 09-26-2014, 03:17 PM Thread Starter
Nails's Avatar
Will the stock fender mounting bolts work with a KW fender and KW blocks or do I need longer bolts? I've got a KW level fender sitting on my work bench waiting to go to the painter with tank and fairing but the weather has been so nice i've been putting off diassembly for paint in lieu riding. Thanks in advance
Nails
Ď19 RG Special
Nails is offline
post #2 of 4 (permalink) Old 09-26-2014, 03:32 PM
Shark of the Month August 13
SIC_26's Avatar
Longer bolts......
OEM fenders have the mount riveted on them that moves the mounting point out to the leg directly, bolt goes through fender into fork leg.
Most (not all) after market fenders are flat on the sides and use a spacer between the fender and fork leg.....IE longer bolts cuz the bolts through fender, through spacer and into fork leg
Typically, if your running a 3/4" spacer (for example) your going to need a 3/4" longer bolt, etc TYPICALLY but not always as there can be a few variables like fender thickness or swapping to a different fork leg with deeper/shallower fender mounting holes. But you get the idea
SIC_26 is offline
post #3 of 4 (permalink) Old 09-26-2014, 03:44 PM Thread Starter
Nails's Avatar
Thanks I assumed that but needed to ask the dumb question. I'll measure the width of the blocks and get the correct bolts.
Nails
Ď19 RG Special
Nails is offline
post #4 of 4 (permalink) Old 09-26-2014, 04:07 PM
With a 1.25" fender spacer you need a 2" bolt, with a 1" fender spacer you need a 1.75" long bolt. So 5/16x18x1.75 or 5/16x18x2
Drew
HogPro is offline
klock werks slicer fender bpt-bagger Equipment-RG 14 11-25-2012 12:01 PM
Klock werks fender questions SIC_26 Paint & Bodywork Section 3 09-11-2012 10:53 PM
Klock werks level fender outlawbulldog Wheels and Tires 10 07-27-2012 01:45 PM
Trade 16" klock werks for 12" klock werks sabre0909 Wanted! (Buy or Trade) 1 05-16-2012 05:47 PM
