Hard Lowers - Road Glide Forums
post #1 of 5 (permalink) Old 11-02-2014, 03:48 PM Thread Starter
Hard Lowers
Hi!
I've written in a couple of times about my troubles trying to install lowers on my 1998 RG. I bought a set from a aftermarket company and received them the other day. All I was supposed to have to do was shorten the piece that rests on the top of the top crash guard and they were supposed to fit. Well they don't the fairing is still to low and the signal lights to far apart on the crash guard. I don't want to raise the fairing or move the signal light brackets. (the bike is totally original) So I guess my question is, up to what year did the older RG's have lowers available. In other words what year do I need to get a set for. As far as i can find out the 1998's didn't have them as an option from the factory.
I've just about beat this thing to death and bought a set of snap on leather chaps which basically solved my wind problem but I would still like a set of hard ones. Any help would be appreciated. Rellick
rellick is offline
post #2 of 5 (permalink) Old 11-02-2014, 09:27 PM
skratch's Avatar
until 2010 when they raised the fairing up an inch, you had to use the roadglide specific lowers, for just the reasons you said. the batwing fairings have the adjustable vent, while the roadglide specific do not. a lot of folks have added their own vent in the lower. while not adjustable, it does allow for some airflow.
skratch is offline
post #3 of 5 (permalink) Old 11-02-2014, 10:54 PM
calgaryglide's Avatar
Rellick,
Do they have to be HD lowers. Have you tried a set of Hogg Chopps? I have a spare set with hardware that I would loan you to test fit to see if they would work for you.
Where are you located in Alberta?
Calgaryglide.
2019 FLTRU, Tyggr
calgaryglide is offline
post #4 of 5 (permalink) Old 11-03-2014, 04:11 AM
do not try the hogg chopps as mentioned in the post above, I have an 01 and it has the same signals as your 98 , I tried the hogg Chopps and they will not work with the signals mounted on the fairing supports, the only lowers I found that work are the Harley specific lowers made to fit 98-03 Road Glides should be part #58841-98 the part number changes with the paint color also be aware if you find a set make sure they come with mounting hardware as the hardware kit is an obsolete part , it was harder for me to find than lowers .
Eagle is offline
post #5 of 5 (permalink) Old 11-03-2014, 09:01 AM
eme56's Avatar
The Classic Motorcycle Vents are adjustable for airflow. With them fully open you do get a lot of airflow. They have tabs in them to keep the doors in the position you set them. With the glove boxes installed, you can't get to the doors while riding. That is the only downside. They fit both the older EG style non-vented lowers and RG style non-vented lowers. I'm not the only one with them. In fact, I found out about them on here.
2005 FLTRI Black Cherry, 95" Big Bore, Thundermax w/Auto Tune, V&H Dresser Duals w/Klock Werks SS, Andrews 26 Cams, SE Stage 1 intake, SE OD/6 Speed, Wards FCS cooling fans, Krome Werks Stretch Heritage +2 bars, Progressive Monotubes, 444's, & Touring Link, Michelin Commander II's, 14.5" Madstad, Lowers with Classic Motorcycle Vents, detachable King Tour Pack, Daymakers
eme56 is offline
Tags
hard lowers
How hard is too hard? tlottman *General Road Glide Discussions/Pictures 11 08-28-2015 06:42 AM
WTB 2014 Hard Saddlebag Hardware..I have lids and Lowers,Just need Hardware :) riteway Wanted! (Buy or Trade) 2 06-15-2014 03:25 AM
12 Ultra Classic hard lowers on 08 RG? Sethjamto Equipment-RG 6 02-27-2014 07:31 AM
Glove boxes for lowers with hard lids 1346wildcat Parts for Sale 2 11-02-2013 12:41 PM
Lowers, lowers and more lowers Garemlin *General Road Glide Discussions/Pictures 57 05-11-2010 09:18 PM
