Custom to Ultra rear fender swap - Road Glide Forums
post #1 of 7 (permalink) Old 11-03-2014, 02:01 PM Thread Starter
GermanyBert's Avatar
Exclamation Custom to Ultra rear fender swap
Just got good deal on a complete, with lights and license plate bracket, rear fender from a 2013 Road Glide Custom.
I want to swap this one with the stock render on my 2011 Road Glide Ultra.
Is this a straight swap or will modification be required?
GermanyBert
2002 Sportster 883/1250 Stage II
GermanyBert is offline
post #2 of 7 (permalink) Old 11-03-2014, 02:27 PM
faststan's Avatar
Should be straight across swap. I replaced my RGU rear fender with an FLHX fender with no issues.
11 FLTRU 103 Red Hot Sunglow
faststan is offline
post #3 of 7 (permalink) Old 03-13-2015, 07:08 AM Thread Starter
Need some assistance. Was talking with the guys at Custom Dynamics and they say it's not a straight swap.
Their exact words were, "If you got the complete fender kit from Harley it should come with an adapter plug that goes from the 8 pin Amp plug that is on your bike to the 6 pin Molex plug that goes with the harness of the Road Glide custom fender."
Does this make sense? Are the rear lighting harnesses for the Ultra and Custom different? If so does anyone know the part number of the custom harness and maybe where I can buy one?
GermanyBert
post #4 of 7 (permalink) Old 03-13-2015, 07:57 AM
lostboy792's Avatar
I went through this when I put a street glide rear fender on my road king. Different plugs. Both were 2010. When I checked into it I found that 2010 was a change in the plug the "X" models got the new style first. I ended up making an adapter to work. Hope this helps.
2012 Road Glide Ultra, BBP. Jackpot head pipe, V&H Monster ovals, VIED's DIY rear air ride suspension, Progressive Mono Tubes in the front -1.
lostboy792 is offline
post #5 of 7 (permalink) Old 03-13-2015, 08:07 AM Thread Starter
After more reading I am discovering I do need the 8 pin to 6 pin adapter.
Anyone know where I can get one of these? Does HD make one?
I read that baddad has the adapter but I can not find it on their website. http://www.baddad.com/
Plus I need 2013 RG Custom rear fender wiring harness. Anyone got the HD part number for this?
GermanyBert
post #6 of 7 (permalink) Old 02-12-2016, 05:20 PM
Question wire adapter
Where did you get your adapter ? I want to swap out fender with out cutting harness.
geno1098 is offline
post #7 of 7 (permalink) Old 02-13-2016, 10:17 AM Thread Starter
Never got one. Still running my original fender.
GermanyBert
Rear fender and fender filler dinggus Equipment-RG 11 09-09-2015 03:40 AM
Canadian rear fender to U.S. rear CVO fender mikehall11 Lighting 10 06-05-2013 01:45 PM
Rear fender filler and fender extension fossil Paint & Bodywork Section 25 11-22-2012 07:12 PM
CVO Ultra / CUSTOM Rear fender with CVO Fascia jokercraze Sold 10 09-20-2012 09:20 PM
