How to clean engine powdercoat/paint effectively - Road Glide Forums
post #1 of 14 (permalink) Old 11-13-2014, 10:18 AM Thread Starter
calgaryglide's Avatar
Ok folks,
Bike is up on the lift for the winter. -21C outside and snow on the ground, ride has switched over to the quad with plow blade (not as fun as it sounds, no tunes).
My engine parts that are black need cleaning. What is the best way to clean the engine transmission areas. I've tried micorfibre cloths but they just drag and spall the cloth. I have seen many bikes where the black areas of the block and transmission look much better than mine and were older.
What is the secret to keeping these areas clean and new looking? In particular what type of cleaning solution and tools are used?
Calgaryglide
2019 FLTRU, Tyggr
calgaryglide is offline
post #2 of 14 (permalink) Old 11-13-2014, 10:29 AM
griswold's Avatar
S100 and a tooth brush with a spray bottle of water
2010 FLTRX, 2003 FXDX, 1983 XLH1000, 1975 FLH
griswold is offline
post #3 of 14 (permalink) Old 11-13-2014, 10:29 AM
93-331-29psi's Avatar
Wash it with engine degreaser and then use that Harley silicone spray to detail it. Will look like new again.
93-331-29psi is offline
post #4 of 14 (permalink) Old 11-13-2014, 11:33 AM
JayKS's Avatar
Originally Posted by calgaryglide View Post
Ok folks,
Calgaryglide
Troy, use HD Engine Brightener on those areas: http://www.harley-davidson.com/store/engine-brightener
The stuff works like magic. You just spray it on and wipe off any excess. I think S100 makes an engine brightener as well, but I haven't tried that one. It's probably the same stuff.
JayKS is offline
post #5 of 14 (permalink) Old 11-13-2014, 11:47 AM
JohnnyC's Avatar
Be careful what you use. Many of those degreasers and cleaners, even the orange based stuff will damage aluminum and alloy metals. Read the bottles carefully.
I'm posting too to see what else is suggested. I damaged my down tubes, engine and primary cases, and wheels with a degreaser one time and the hours it took to polish them back up could have been spent riding.
2014 Electra Glide Ultra Classic FLHTCU / Birch White & Midnight Pearl / Bought New 02/13/15
SOLD 03/23/15 1986 FLTC Tour Glide Classic EV27/9.6:1 K&B Hypereutectic/S&S Shorty E/Crane Hi4e/167k
JohnnyC is offline
post #6 of 14 (permalink) Old 11-13-2014, 12:09 PM
JayKS's Avatar
Good point JohnnyC. I recently found out that Simple Green isn't safe for aluminum. I've started using Simple Green Pro HD. It's a pink/purple color. It can be had at Home Depot and the label says it's safe for aluminum.
JayKS is offline
post #7 of 14 (permalink) Old 11-13-2014, 12:10 PM
124shark's Avatar
To get the case to look new again.
Clean the engine case Tooth brush works great,,, the cheap electric ones you can buy for kids work even better Arm & hammer spin brush is 6 bucks at walmart 1000 hr battery
Warm water and cheap dish soap will clean it right up.
Once done use your "shine product of choice"
Once you use the silly tooth brush you are going to find all kinds of other things to clean with them.. They clean the grime off that rear rim very well and with almost no effort. We bought a few for the grand kids and well I snagged a extra the wife had put away.
Might even clean a ford stroker with boost 29 PSI 68 or 72 MM ??
2012 FLTRX 124 S&S
124shark is offline
post #8 of 14 (permalink) Old 11-13-2014, 01:51 PM
76mm
post #9 of 14 (permalink) Old 11-13-2014, 05:24 PM
Hullhorr's Avatar
I'll have to read my bottle of Simple Green, but this is the first I have heard about this. I've been cleaning the engine on mine since new with it and zero damage. Could be because you are cleaning the powder coated finish covering the aluminum and not necessarily direct contact with the aluminum.
2009 FLTR MOP
Hullhorr is offline
post #10 of 14 (permalink) Old 11-13-2014, 06:01 PM
S100 engine brightner works great.
powdercoat vs paint a front fender ?? redbaron Paint & Bodywork Section 7 04-13-2014 08:30 AM
2002 FLHRI Road King, Super clean, custom paint aclass Bikes for Sale 1 07-31-2013 12:31 PM
Powdercoat my chromedome modot66 Paint & Bodywork Section 7 11-17-2011 10:08 PM
Powdercoat Chasesstreetbob Paint & Bodywork Section 7 10-15-2011 01:33 PM
Need Powdercoat near Montgomery AL Defy *General Road Glide Discussions/Pictures 1 02-22-2011 06:40 PM
