Powder coating floorboards - Road Glide Forums
post #1 of 12 (permalink) Old 12-01-2014, 09:06 PM Thread Starter
MASQUEDMANN's Avatar
In the process of blacking out all the chrome. The floorboards and passenger pegs have rubber in them can they be removed and put back in after powder coating
Tia
Masque
MASQUEDMANN is offline
post #2 of 12 (permalink) Old 12-01-2014, 10:03 PM
anonymous_1's Avatar
Cool. Good luck.
2013 Road Glide Ultra, House of Kolor custom paint, 4" Rinehart true duals, Fuel Moto AC, Power Vision, Covington covers, Biketronics 7.1" front and rear with BT4180 amp and Alpine 164bt, Hogpro 21" 6-pack
anonymous_1 is offline
post #3 of 12 (permalink) Old 12-01-2014, 10:15 PM Thread Starter
Thanks any idea about removing the rubber to get them powder coated
post #4 of 12 (permalink) Old 12-02-2014, 04:22 AM
Yes, the rubber pieces can be removed but I have yet to come up with a solution for the chrome strips in the middle yet.
For the floor boards... Flip the boards over and with a pair of needle nose pliers squeeze the "bulbs" sticking through and push them through. For reassembly I recommend soapy water.
Brake pedal..... Remove the nut on the back of the pedal to remove the pad and chrome surrounding the pad.
Passenger pegs...... Remove the allen bolt on the outboard side of the peg. Next slide the peg mounting post out of the peg and remove rubber insert.
Hope this helps
mray81 is offline
post #5 of 12 (permalink) Old 12-02-2014, 07:24 AM Thread Starter
Mray81 thanks will be doing as you suggest today. I'm gonna keep the chrome strip to give some contrast. Let you know how it all turns out.
post #6 of 12 (permalink) Old 12-02-2014, 08:52 AM
Jetman's Avatar
There is a 2 piece plastic bushing inside the brake arm where the spline goes thru that needs to be removed before the item is coated (plastic won't stand up to the required curing heat) and then it needs to be re-installed.
Not sure what all you have in mind or where your located, but I have a pretty healthy supply of parts in my exchange program and can help you eliminate most of your down time. PM me for any powder coating questions......
2012 - Big Blue Pearl
Heavily Accessorized.....
Jetman is offline
post #7 of 12 (permalink) Old 12-02-2014, 03:35 PM Thread Starter
pm sent thanks for the heads up on the plastic bushing
post #8 of 12 (permalink) Old 12-02-2014, 04:20 PM
Willy_B's Avatar
Jetman does great work!! He's done a lot on my bike and everything was flawless!!
Willy_B is offline
post #9 of 12 (permalink) Old 12-02-2014, 05:11 PM
Jetman's Avatar
Thank you for the kind words......
We need to get together soon before it gets too dang cold!!
Jetman is offline
post #10 of 12 (permalink) Old 12-02-2014, 06:53 PM Thread Starter
Hope this helps
yes it helped got all the rubber pieces out today thanks
Powder coating my wheels got a ?? slowglide2989 *General Road Glide Discussions/Pictures 4 08-25-2010 12:05 AM
Powder Coating - What company/color to match Vivid Black Tytanium *General Road Glide Discussions/Pictures 1 07-07-2010 11:50 PM
powder coating raven006 *General Road Glide Discussions/Pictures 13 02-27-2010 07:50 PM
More powder coating done FLTR2008Trike *General Road Glide Discussions/Pictures 2 02-20-2010 03:02 PM
Powder Coating ATrain *General Road Glide Discussions/Pictures 8 01-19-2010 07:08 PM
