Can anyone help? Guide? - Road Glide Forums
post #1 of 21 (permalink) Old 12-12-2014, 08:35 PM Thread Starter
RGLove12's Avatar
Need help all the body, fairing guru's please guide me to fix this issue??
Dave Mackie 575 Cams, Master Tune TTS, V&H High output, Agitators, Blacked out, C&C Seat, CVO Guages
RGLove12 is offline
post #2 of 21 (permalink) Old 12-12-2014, 08:54 PM
torqu's Avatar
You'll have to use some type of epoxy or JB weld and tap it out.
torqu is offline
post #3 of 21 (permalink) Old 12-12-2014, 08:57 PM
Devcon or Red hand
cbumdumb is offline
post #4 of 21 (permalink) Old 12-12-2014, 09:01 PM
perrykw's Avatar
+1 on the JB Weld type products or take it by a body shop and let em shoot a little bumper epoxy on it
perrykw is offline
post #5 of 21 (permalink) Old 12-12-2014, 09:41 PM
twistr's Avatar
I did the JB weld when one of those went south on me (stripped threads)...here's what I did.
Use JB weld...once it starts to set take the screw and screw it in. Prior to doing so, take your wife's cooking "Pam" spray and apply liberally to the screw. This will help keep the epoxy from sticking to the screw. Let the epoxy dry and screw out the screw...your done...worked for me with no issues what so ever. Have taken off outer fairing several times once repaired...sorry I have no pics.
Good luck
Riding Life's Twisting Roads...
On a 2008 Dark Blue Pearl Road Glide
twistr is offline
post #6 of 21 (permalink) Old 12-12-2014, 11:53 PM
^^^^^^^^^same here, do it above 70 degrees and let set for good 12 hrs, plus thin out the jb with denatured alcohol, or use rubber cover repair, I'll find some pic's
reds4 is offline
post #7 of 21 (permalink) Old 12-13-2014, 12:14 AM
they somewhere, but those or pieces of the inner fairing repaired with the flexible, dremeled down before paint, can't tell. It will help if use a soldering iron to kinda melt/weld to hold first, align prefectly, you can do it. Also use the screw to thread up&down slightly after several hours of drying to make sure it will hold tork. Don't even try superglue. prep up the surrounding area (scotch bite or dremel) alcohol wipe and thin out the jb, works everytime. On your pic, you are gonna havta build the repair up
reds4 is offline
post #8 of 21 (permalink) Old 12-13-2014, 12:17 AM
Those are great suggestions and ill have to give that a try but it looks like (in the posted pics) that there's actually pieces of it missing. Can the J-B weld still be used
post #9 of 21 (permalink) Old 12-13-2014, 12:22 AM
torqu's Avatar
I don't personally use the JB weld. I use the products from Fusor. They have numerous 2 part epoxies for ABS, Fiberglass, & steel. They are expensive but we'll worth it. You can mold and shape it also.
torqu is offline
post #10 of 21 (permalink) Old 12-13-2014, 08:12 AM
twistr's Avatar
Originally Posted by rlaf75 View Post
....that there's actually pieces of it missing. Can the J-B weld still be used
Yes...the JB Well can be shaped while its hardening or applied building up the area as it sets.
twistr is offline
The Tour Glide / Road Glide History - a complete information guide CHAINSAW *General Road Glide Discussions/Pictures 230 06-01-2019 08:31 AM
I Can't Wait I Can't Wait I Can't Wait......The Outdoors SteadyEddie General Off-Topic Discussions 15 05-19-2017 02:57 PM
Clutch cable guide Howardsternspenis *General Road Glide Discussions/Pictures 6 09-01-2011 04:46 PM
Tech Guide online BillyBob *General Road Glide Discussions/Pictures 0 01-05-2010 04:27 PM
