SG Rear Fascia on a RG Ultra - Road Glide Forums
post #1 of 14 (permalink) Old 01-19-2015, 06:04 PM Thread Starter
RoadGypsy's Avatar
I'll be surprised if this hasn't been covered here, a time or two, but please forgive the new guy. I'd like to install the SG rear fascia and and tri-bar light on my 2013 RG Ultra, but I don't know if it will fit.
Anyone have any experience with this project? If it's located someone else, I appreciate some direction finding it.
RoadGypsy is offline
post #2 of 14 (permalink) Old 01-19-2015, 06:09 PM
PHere's a thread. There are others. Its easy. Just make sure you get the tri bar for a 2009. Here's a pic of mine. http://www.hdforums.com/g/picture/777286
I added a custom dynamics led laydown taillight and turn signals with their controller. Now the signals, lay down taillight and tribal all are synced as run turn brake and have the same flash pattern. Lots of light.
https://www.roadglide.org/showthread.php?p=433367
Give Jon at horny toad hd a call and he'll fix you up on parts.
2013 Ultra
Pics here:
rg_dave is offline
post #3 of 14 (permalink) Old 01-19-2015, 06:39 PM
It's very easy to do.
post #4 of 14 (permalink) Old 01-19-2015, 06:58 PM Thread Starter
RoadGypsy's Avatar
Thanks
Thanks. Hope to get this done before spring.
post #5 of 14 (permalink) Old 01-19-2015, 08:53 PM
If you buy the tri bar light for your year bike it should be plug n play. Also to let you know, the way the fascia is attached is by bolts through the fender. Some choose to use double sided tape but bolting it is the stock original way. I installed it by drilling holes.
post #6 of 14 (permalink) Old 01-20-2015, 07:26 AM
I did mine last year, and very simple. I did not drill mine, I used double sided tape. No problems and many have done it this way on this site, look for threads.
2012 Road Glide Ultra
antant is offline
post #7 of 14 (permalink) Old 01-20-2015, 09:19 AM
If you drill make sure you paint the inside and outside of the fender. (I drilled mine. No big deal)
2013 Ultra
Pics here:
rg_dave is offline
post #8 of 14 (permalink) Old 02-28-2015, 01:06 PM Thread Starter
RoadGypsy's Avatar
Thanks
Thank you all for the help. Now the decision to drill or tape? Depends on how froggy I feel.
post #9 of 14 (permalink) Old 02-28-2015, 01:25 PM
It's really not that difficult to drill. Mask off the fender where the fascia sits on it, have someone hold it in place while you mark the hole locations Where you masked off. Slide a piece of wood or similar in between the fender and tire so you don't puncture the tire and to firm up the fender while drilling. It really is easy and I'd recommend doing it this way as it's the factory method
post #10 of 14 (permalink) Old 02-28-2015, 01:50 PM
Mark62's Avatar
Post
You should find all info on this forum including a detailed parts list. I had it done to my RGU last year. Great looking mod too, looks finished now. I had HD do the work and provided the parts list from this forum. I didn't care for the tape idea mine is drilled.
2013 RGU Vivid Black / SE 204 Cams / SE Heavy Breather / SE Super Tuner / Most chrome PC Blk / Reinhart Black slip ons / Black Ice Wheels / De-Cat Header / Pow-Mia Theme in remembrance of my Papa Joe, U.S.S Houston.
Mark62 is offline
Documented SG Fascia Install on 2012 FLTRU (PDF Available) 2012FLTRU_BigBlue Do-IT-Yourself 61 06-26-2019 08:16 PM
2006 SG Light bar and Fender Fascia Lunchboxx Paint & Bodywork Section 1 09-09-2015 11:03 AM
SG fascia install 02heritage Paint & Bodywork Section 3 12-20-2013 06:20 PM
Pewter Pearl Owners with SG fascia Venomized Paint & Bodywork Section 6 11-28-2013 12:40 PM
SG Rear Fascia - Drill or 3M tape Lu *General Road Glide Discussions/Pictures 13 01-02-2011 08:20 PM
