tour pak wire harness hole location? - Road Glide Forums
post #1 of 1 (permalink) Old 01-25-2015, 06:44 PM Thread Starter
Just finished mounting a lighted spoiler kit to my new tour pak (still waiting on the back rest and lock cylinder). The supplied template is a little undersized, and not very precise with all of the rounded edges. I did a little "customizing" with a small rat tailed file on 2 of the holes, and I think it ended up pretty even. Also not real thrilled with the big black spacer bar on the front, but it's mostly hidden. The directions for the wire harness outlet location are pretty vague. I think it says "in the corner of the tour pak". My older king tour pak had a circle molded into the bottom for the exact location. This is on a chopped tour pak with the much smaller back rest. I'd like the wiring to be less obvious if possible. I might run the wire into one of the molded channels under the interior steel plate and exit the harness between the tour pak and the mounting rack. Any better ideas?
Hellbent is offline
Tour Pak Brake Light wire harness arlemke Lighting 2 07-14-2012 08:32 AM
Hotel Issues - location location location DreamRider ARCHIVES-SWII LeClaire, IA 29 07-11-2012 12:40 PM
Tour Pak Rear Speakers Harness RoadGlideRider Sold 1 05-10-2012 02:45 PM
Hole in King Tour Pack for Antenna Wire Bud Seating: seats, backrests 6 03-13-2011 03:21 PM
wiring harness for Classic style Tour Pak prince Lighting 4 01-20-2011 12:48 PM
