Headlight trim removal - Road Glide Forums
post #1 of 16 (permalink) Old 02-04-2015, 07:09 PM Thread Starter
OK,w hat's the trick to removing the plastic panel that covers the head lights? It's held on by four tabs, and I just broke two of mine off trying to remove it! Lucky for me, it's only a $10.00 part! The service manual says "pry gently." Yea, right, like I'm going to take a screwdriver to my painted fairing. Got to be an easier way.
Motormike is offline
post #2 of 16 (permalink) Old 02-04-2015, 07:33 PM
Djtman's Avatar
I did it with a flat screwdriver with painters tape wrapped around it. It's in your best interest to youtube anything you are DIY on the bike to save yourself some agony!
DJ Terry Moran
2013 FLTRX Candy Orange, cruise/abs, 1988 FXRP mopar orange (traded), 1996 Kawa ZL600 eliminator (restoring) I'm a DJ, spinning bike week Laconia 15 yrs
Djtman is offline
post #3 of 16 (permalink) Old 02-04-2015, 07:47 PM
moose1's Avatar
Same here a flat screwdriver and a little tape. I just pop out the top and it comes right off no problem
2012 FLTRU vivid black
moose1 is offline
post #4 of 16 (permalink) Old 02-04-2015, 07:51 PM Thread Starter
I had the fairing off the bike, and still coudn't remove the trim piece without breaking the tabs.
post #5 of 16 (permalink) Old 02-04-2015, 08:49 PM
Sounds like the black edge trim/or sides of bubble buggut encrusted and/or heat swelled, 10 bucks? why worry
reds4 is offline
post #6 of 16 (permalink) Old 02-05-2015, 07:14 AM Thread Starter
True, except I have to wait for the part. Not something a dealer would keep in stock. I was using the "headlight removal" technique to re-mount the fairing. Much easier to do when you can see the two little fairing hooks through the headlight opening. Think I may try some heavy duty velcro to hold the old one in place until the new part arrives. At least I was able to clean out all the old dead bug guts.
post #7 of 16 (permalink) Old 02-05-2015, 08:38 AM
PGR
PGR's Avatar
The trick is to leave the screwdriver in your tool box....... use a butter knife. Less chance of breaking the tabs or chipping your paint.
Push the knife in until it hits the tab. Apply a little torque, and pull out on the bezel. Start with the bottom first, as it comes loose a little easier.
Ron..........................
PGR is offline
post #8 of 16 (permalink) Old 02-05-2015, 10:14 AM
+1 on the butter knife.
post #9 of 16 (permalink) Old 02-05-2015, 11:08 AM
+2 on that butter knife. Its thin enough to slide between the bezel and the fairing but firm enough to apply pressure without causing any damage
post #10 of 16 (permalink) Old 02-05-2015, 11:13 AM
JJSW1283's Avatar
Lol I thought I was the only one that used a butter knife. I have electrical tape wrapped around it.
JJSW1283 is offline
Rear footpeg removal trim eric.d.stanton.3 Seating: seats, backrests 4 03-25-2018 03:57 PM
Windshield trim removal help turbokider Windshields 2 10-26-2012 12:56 AM
Windshield Chrome Trim Removal Question FireGuy88 Windshields 6 10-12-2012 09:12 AM
Headlight change vs. fairing removal ODA CDR (RET) Road Glide Specific Discussions 44 01-16-2012 02:51 PM
Headlight cover removal 71u140 Lighting 6 05-21-2010 02:50 PM
