Repair speaker holes on side? - Road Glide Forums
post #1 of 7 (permalink) Old 02-10-2015, 05:47 AM Thread Starter
ScreamingSkulls's Avatar
So i did the "mount 6x9" on the inside of the bags facing the rear wheel mode. I've now decided to get some hogtune lids and need to seal and fix all the little still holes i created. I'm assuming some fiberglass but wanted to ask you guys if you suggest anything else.
Thanks in advance.
ScreamingSkulls is offline
post #2 of 7 (permalink) Old 02-10-2015, 06:15 AM
If you have OEM bags it's probably easier to buy another set, you can find them pretty cheap on ebay. If they're extended, I don't know.
post #3 of 7 (permalink) Old 02-10-2015, 06:35 AM
OneSlickGlide's Avatar
You could use fiberglass however I've had good experience with SEM Carbofill. It's a carbon fiber reinforced filler.
Gets extremely hard, is fairly easy sandable AND is not prone to shrinkage.
OneSlickGlide is offline
post #4 of 7 (permalink) Old 02-10-2015, 06:42 AM
09Sharknose's Avatar
Do you have one big hole or a bunch of little holes that kind of look like a speaker grille?
If it's the one big hole, buy new bags. If it's the small holes, leave them for now until you install the lids. They may provide a port to make your lids thump more.
09Sharknose is offline
post #5 of 7 (permalink) Old 02-10-2015, 06:43 AM
torqu's Avatar
Lord Fusor products. They are expensive but are great products. They make an epoxy for abs. Why not just run 4 6x9's in the rear? Hell I would. But it's gonna come down to money. As Dbell has already stated, it's gonna be alot easier to just replace yours with a different set, then sell your old ones.
torqu is offline
post #6 of 7 (permalink) Old 02-10-2015, 07:44 AM Thread Starter
I have a bunch of little holes. My excuse to the Wife for the lids was so i could get storage back in the bags so doing 4 6x9 would defeat that argument.. Lol.
They are stock bags.
post #7 of 7 (permalink) Old 02-10-2015, 09:23 AM
RoadHawg's Avatar
Cover the outside area with the holes with 2" tape then trowel the plastic reapair material on the inside of the bag, after its cured pull off the tape and the outside should look reasonably fine since its a hidden area.
Mikes Hawg Paint, Camino, CA.
RoadHawg is offline
Inside fairing cubby holes next to speaker pods question for 2015-2018 Heavy Metal Do-IT-Yourself 2 02-08-2018 11:18 AM
[Q] Inner Fairing Speaker Holes dinggus Do-IT-Yourself 3 05-29-2016 10:58 AM
Seeking Inner Fairing With Larger Speaker Holes Shrug *General Road Glide Discussions/Pictures 5 04-16-2016 09:02 AM
side covers or side panels Graybone32 *General Road Glide Discussions/Pictures 8 09-27-2011 09:42 PM
pluging speaker pod holes frogman6042 Do-IT-Yourself 4 04-13-2011 09:13 PM
