Powdercoating Mirrors?? - Road Glide Forums
post #1 of 13 (permalink) Old 03-04-2015, 12:08 AM Thread Starter
brhodea's Avatar
I'm in the process of powdercoating all of the chrome on my '11 RGU. Does anyone have any input on coating the mirrors?? I'm not sure if the glass will hold up in the baking process. I'm not sure if should save the headache & just buy new or go ahead & have them coated.
while I'm at it, I'm also planning on having both stock RGU wheels coated, has anyone seen the finished product? how's it look??
Thanks
brhodea is offline
post #2 of 13 (permalink) Old 03-04-2015, 06:30 AM
bucketlisthd's Avatar
My coater says the glass must be removed. I tried heat to break the adhesive. No go for me. I ended up just doing the stems.
'15 Roadglide Special
'87 FXR 100"
'79 Goldwing cafe
bucketlisthd is offline
post #3 of 13 (permalink) Old 03-04-2015, 06:59 AM
Jetman's Avatar
The glass will need to come out to allow the part to be cured at the proper temp...
2012 - Big Blue Pearl
Heavily Accessorized.....
Jetman is offline
post #4 of 13 (permalink) Old 03-04-2015, 09:24 AM
jupiter's Avatar
FYI-the Harley black PC ones I bought in 2012 were rusted by 2013. The stems.
Plus they only supplied regular chrome acorn nuts with them. WTF????
Don't know if the new ones were any better. I just Plasti-dipped the stems the other night. The actual dip type plastic dip.
Priscilla- 11 RGU VB with FM intake, HP, DT mufflers and FM tune.
jupiter is offline
post #5 of 13 (permalink) Old 03-04-2015, 10:33 AM
Paul's Road Glide's Avatar
a heat gun will take forever to remove the glass. There is some crazy haenous glue that holds the mirror in place. I've found that baking the whole thing in the oven, mind you prior to any powder, that it will soften the glue enough so you can pull apart. Actually if you lay the mirror glass down and after about 15-20 minutes of a good sustained 300 degree temps, when you go to lift the mirror the glass should just ooze off so to speak.
...and I'm assuming these are stock HD mirrors.
Paul's Road Glide is offline
post #6 of 13 (permalink) Old 03-04-2015, 02:21 PM
1extremeskier's Avatar
Just buy russ weirmont black
2013 Candy Orange, MGS True Duals, SE A/C, Handlebar Lee 18" Cordovas, 21" Primo "CALI" Wheel, KW Level 21" fender, Progressive 444 & Monotubes, Kenwood KDC-X998, Biketronics BT4180, 7.1 PRO, 6X 9 in lids
Blacked out with some chrome for accent
1extremeskier is offline
post #7 of 13 (permalink) Old 03-04-2015, 07:53 PM
You can powder coat your mirrors without any issues as long as the coater knows what needs to be done. Ive powder coated at least 10 sets without any issues. I had to build a jig to hold the mirrors correctly when they are placed in the oven.
daryl_db is offline
post #8 of 13 (permalink) Old 03-05-2015, 05:49 PM
Hullhorr's Avatar
I wouldn't take the chance powder coating them with the glass in them. Just buy ones that are already black.
I powder coated a real wheel for mine, but it was the FLTRX wheel not the ultra wheel. I'm real happy with it because it just disappears under the bike. Stripping the old finish was a chore though. If you do this be sure to add a 90-degree valve stem.
2009 FLTR MOP
Hullhorr is offline
post #9 of 13 (permalink) Old 03-05-2015, 06:02 PM
Q-Hog's Avatar
Just take the mirror out before powder coat the reinstall it. That's what I did.
Q-Hog is offline
post #10 of 13 (permalink) Old 03-06-2015, 02:47 AM
sj01fltri's Avatar
Did you heat in the oven and if so what temp and for how long.
sj01fltri is offline
powdercoating pool??? brettnbama *General Road Glide Discussions/Pictures 5 06-03-2012 07:56 AM
powdercoating engine guard THEMASTERDESTROYER Aftermarket Accessories 8 10-17-2011 07:52 AM
powdercoating hognit *General Road Glide Discussions/Pictures 3 04-17-2011 05:33 AM
Wheels back from powdercoating - now I make them mine Sincecrazy *General Road Glide Discussions/Pictures 13 01-30-2011 08:20 PM
Custom powdercoating voodoo041672 *General Road Glide Discussions/Pictures 14 02-02-2010 03:16 PM
