Microscratches Eliminated - Road Glide Forums
post #1 of 15 (permalink) Old 05-28-2015, 06:32 AM Thread Starter
Since my bike was new, it has had the fine microscratches that were very noticeable in direct sunlight.
Last week I decided to see if I could eliminate them without abrasives. I washed the bike, and put on a coat of Liquid Glass, which is a polish and sealer. Following the directions, I put it in the sun for a few hours to bake. Then I blew off the dust, cleaned it up and put on a second coat and baked it again. Then I put on two coats of Meguiars Ultimate and no (and I do mean no) microscratches are visible at all. I told a buddy about this and he tried it on his 2011 RG CVO and got the same results.
The black paint looks like glass now and I didn't have to buff into the clear coat. I'm sure some will come back over time but at this point all I will have to do is clean it up and put on a coat of Meguiars which I do a couple of times a year anyway.
Captain13 is offline
post #2 of 15 (permalink) Old 05-28-2015, 06:44 AM
RGKen's Avatar
Great info! I will have to try this. Thanks!
2018 FLTRXS
RGKen is offline
post #3 of 15 (permalink) Old 05-28-2015, 01:38 PM Thread Starter
Just using Liquid Glass or Meguiars alone won't do it. They have to be used together. I discovered this when trying to work out the same problem on my truck. The dealer had put on some type of protective coating and the black paint looked like nothing but red scratches in the sunlight. I was pissed when I discovered it (I won't buy another vehicle on a cloudy day). Their solution was to send it to a body shop and buff it. That cuts into the clear coat even more. So I tried this method and only used one coat of liquid glass. The scratches were the same. With Liquid Glass you still have to apply wax. LG is a sealer and quickly loses its ability to bead water. You also get a lot of water spots in it it you don't wax as I found out on the bike. So applied the LG, baked it that afternoon and then waxed the next day. So long micro scratches. The paint is now smooth and reflective like it should be. Water beads and runs right off.
post #4 of 15 (permalink) Old 05-29-2015, 12:21 PM
Deadstroke's Avatar
awesome making a note of this
Deadstroke is offline
post #5 of 15 (permalink) Old 05-29-2015, 09:38 PM
hogboy57's Avatar
Sounds good going to try. Thank you.
2017 laguna orange road glide special c&c solo seat xm radio harleys 18" black blade rims cyclesmith bananaboards chrome front end progressive ultra low rear shocks dragons slip on mufflers painted inner fairing DD ghost chrome handlebars 9" black windvest windshield coo rear fender
hogboy57 is offline
post #6 of 15 (permalink) Old 05-29-2015, 10:29 PM
RoadGlideGary's Avatar
Now I have another task to under take! Once this rain stops for more than a day I know what my ride is going to get. Definitely going to put this finishing touch on my custom Air Brush ride. Thanks!
05' SuperGlideCustom - sold
RoadGlideGary is offline
post #7 of 15 (permalink) Old 05-30-2015, 01:37 PM
Thanx for the info.
2012Road GlideUltra-Vivid Black,Vance & Hines Two into One Pro Pipe,Screamin' Eagle Race Pro Tuner,Screamin' Eagle High Flow Air Filter,16" L.A. Choppers Apes,16" Klock Werks Windshield,Hogtunes Big Ultra RG Audio Upgrade Kit,"Tall Boy" Seat,Chrome Levers,Grips,TurnSignalVisors. Powdercoated Fork Lowers&Cowbells,Metzeler Marathon 888's,Gold Valve Cartridge Emulators,GloveCompartment, Saddlebag,Trunk and Lower Fairing Liners,Highway pegs, Legend Revo-A's,Hog Trough Cup Holders
kevinhd1690 is offline
post #8 of 15 (permalink) Old 05-31-2015, 07:02 AM
Captain13
Is this the product?
Liquid Glass LG-100 Ultimate Auto Polish/Finish - 16 oz.
Is it available at most auto parts stores.. NAPA, Pep Boys, Auto Zone etc??
Thanks again for posting this info.. I've tried everything to remove my scratches
with no luck.
Mike
mpears53 is offline
post #9 of 15 (permalink) Old 06-01-2015, 12:13 PM
One of the 2, or both, of the products you used must have had some fillers in them. I don't use those products so I don't know. The micro marring is still there but the fillers hid them.
Micro marring most of the time comes from washing and drying. Using quality microfiber products helps, along with an electric leaf blower to dry the bike.
My bike is vivd black and it is the softest paint I have ever worked on. If you look at it the wrong way it would mark the paint. This past weekend, I polished and put a ceramic coating on it. Now when I wash it I am touching the coating and not the paint.
phillyfan1 is offline
post #10 of 15 (permalink) Old 06-04-2015, 05:08 PM
Methos1979's Avatar
Let's see some PHOTOS!!!
2013 Road Glide Custom CVO in Roman Gold/Burnt Emerald, Le Pera Maverick, Vance & Hines Power Duals, SERT, MadStad 13", Kury ISO grips & Scythe mirrors.
Methos1979 is offline
Pinging Eliminated lldsilver41 ECM/Fuel Management systems 17 08-05-2013 07:47 PM
