2015 front fairing crooked - Road Glide Forums
 3Likes
post #1 of 20 (permalink) Old 07-07-2015, 09:37 PM Thread Starter
Bender15's Avatar
Decided to measure from the bottom of my front fairing to the top of the crash bar. Left side is 3 3/4" and the right side is 4". anybody else have this issue?
Should I take it to Harley and have them fix it? Bikes a month old
Bender15 is offline
post #2 of 20 (permalink) Old 07-08-2015, 09:32 AM
Mine is off as well. Didn't measure it but if you look closely you can see it. Took it to the dealer and they didn't feel it was worth messing with. I really don't notice anything going down the road so unless I have a reason to get inside the fairing I will just live with it.
I was told that maybe loosening the fairing to crash bar mounts may allow it to straighten out. Haven't tried it.
AFDHarley is offline
post #3 of 20 (permalink) Old 07-08-2015, 10:50 AM Thread Starter
Bender15's Avatar
I adjusted mine. Took the outer fairing off. The headlight out. Loosened all the bolts a d slid it to the top on the crash bar mounts. Tightened everything down. Doesnt take that long. And I took some pix if needed
Bender15 is offline
post #4 of 20 (permalink) Old 07-08-2015, 06:22 PM
If you don't mind please post them or email them to me.
[email protected]
Thanks
post #5 of 20 (permalink) Old 07-08-2015, 07:07 PM
Admin
BillyBob's Avatar
That's interesting. Let us know what happens 😁😁
BillyBob is offline
post #6 of 20 (permalink) Old 07-08-2015, 11:53 PM Thread Starter
Bender15's Avatar
Very simple to remove front fairing. Sorry for the lack of pictures.
Take the Philips head screws off the windshield. remove it
To get the Upper vent off you will just pop it up from the front.
Unplug the turn signals. The connectors are on each side by where the windshield mounts are. Very noticeable. (labeled in pic)
Slide your hand in behind the inner fairing to pop off the speaker grills.
There is 1 Torx head screw on the outboard side of each speaker. Remove them.
Remove the lower torx bolts from the wind deflector on each side. Not necessary to remove the entire wind deflector.
Now is where you will want a second person. Or, like in my case, I could reach them.
Remove the allen head bolt from each turn signal. When you do this the front fairing is free. Be ready. Slide the front fairing to the front of the bike. Its off !
Now to adjust the whole fairing. You will have to remove the headlight.
Before removal unclip the 2 wire bundles from the top of the headlight.
There's 4 allen head bolts holding the headlight in (labeled in pic) and a connector on the back.
Behind the headlight is 4 inner fairing mount bolts. Just loosen those.
On each side where the mounts from the crash bar mount to the fairing. You will loosen those. (as you can see. My left was was a 1/4" lower than my right)
The fairing will drop a bit but not fall off. (all we did was loosen them !)
I started with the rear mounts and held them up as high in the bracket as it would go, and tightened the bolt down. Then moved to the front to do the same.
The process is reverse for assembly. Remember when re-installing your outer fairing it clips onto your inner fairing on the rear, on both sides.
Pictures are attached. Any other questions just ask.
Bender15 is offline
post #7 of 20 (permalink) Old 07-09-2015, 08:49 AM
Thank you very much for the pics and instructions. Maybe I'll tackle this some day when it's too bad to ride. Looks pretty simple to do really.
post #8 of 20 (permalink) Old 07-09-2015, 04:48 PM
Admin
BillyBob's Avatar
Bender, thanks for the photos I'm going to sticky this 😎😎
BillyBob is offline
post #9 of 20 (permalink) Old 07-09-2015, 05:22 PM
captainoverdrive's Avatar
Great job! Thank you for the information and pics
captainoverdrive is offline
post #10 of 20 (permalink) Old 07-09-2015, 10:22 PM Thread Starter
Bender15's Avatar
Originally Posted by BillyBob View Post
Bender, thanks for the photos I'm going to sticky this ����
Glad I could help !
Bender15 is offline
Crooked bars?? bogie Controls & Handlebars 17 03-19-2015 09:59 AM
Crooked muffler BrewCitySinner Intake and Exhaust 5 03-19-2015 05:38 AM
2013 fltru fairing crooked Mountainman *General Road Glide Discussions/Pictures 9 03-21-2014 09:54 AM
crooked fairing or bars? help Gonekat Troubleshooting for Road Glides 4 03-20-2014 09:56 PM
inner fairing makes handle bars look crooked hogboy57 Paint & Bodywork Section 13 10-28-2013 09:26 AM
