Mutazu lower tour pak fitment ??? - Road Glide Forums
post #1 of 3 (permalink) Old 08-21-2015, 01:43 PM Thread Starter
Will the Mutazu lower tour pak section fit a Harley lid?? I have a Harley classic tour pak and it has some stress fractures in the bottom trunk but the lid is good so I was looking at either doing a R&R on the tour pak bottom I have or buying a new bottom.
post #2 of 3 (permalink) Old 08-21-2015, 02:13 PM
lil chief's Avatar
It should fit, but something somewhere like the holes for the hinges or latches might be slightly off. As far as repairing your lower box, I patched several holes in mine from where the rear speaker pods & wiring holes were. What I did was I used some mesh drywall tape & adhered it over the holes from the inside with abs plastic repair. I then filled the holes from the outside with the abs plastic repair & ulitmately smoothed them out with lightweight body filler. Just a warning though, any excess of the abs repair is really really tough to smooth out. I had to use a da sander with 80 grit paper on it just to get them smooth enough to use body filler over them.
Lil Chief
lil chief is offline
post #3 of 3 (permalink) Old 08-21-2015, 03:48 PM
Mike U's Avatar
Mark, the Mutazu Tour Packs are from the earlier version of the OEM TP I believe up to 2006.
If you give Mutazu a call at (510)483-3658 and ask for Patricia or Gina tell them you're a Member of Roadglide.org I'm sure they will be able to answer your question.
Best of Luck!
Mike U.
USMC 1975-1977
Semper Fi!
Nothing else matters!
Mike U is online now
Premium Latches & Hinges on a Mutazu Pak? lil chief Aftermarket Accessories 4 01-19-2016 06:04 PM
Mutazu Lower Fairing ISSUES!!! PieDog Aftermarket Accessories 42 11-20-2015 04:58 PM
Yes The Mutazu Lower Work On 2014-15 Touring Bikes Swomack Aftermarket Accessories 30 11-07-2015 12:59 PM
Mutazu Lower Fairing Big_gary Equipment-RG 6 06-09-2015 10:23 AM
Mutazu King Tour Pak 2009-2013 questions fcheshir Aftermarket Accessories 14 03-28-2015 04:54 PM
