Corner of inner fairing is popped out. Looking for suggestions on a fix - Road Glide Forums
post #1 of 4 (permalink) Old 12-01-2015, 11:17 PM Thread Starter
I have a 2015 Road Glide Special with about 1500 miles on it. Getting on the bike today I noticed that the right corner of the inner fairing is popped out about an 1/8th to a 1/4 of an inch. The other side is flush. Since it's still under warranty I'm going to try and take it to the dealer this weekend but I thought I'd post here and see if there's a quick fix I could try. I have tried pushing on it but had no luck. If nothing else it would be great to have some knowledge on how this could have happened or what the problem might be before I go in to talk to the dealer. Thanks. I've attached two photos. The one on the left is the popped out corner. I included one of the other corner to provide a comparison.
USMCEOD is offline
post #2 of 4 (permalink) Old 12-01-2015, 11:52 PM
EODHOG's Avatar
Send a message via Yahoo to EODHOG
Odd
Did you put a windshield on it? You should be able to loosen the inner fairing screws and pop the inner and outer back together. You'll need a T-27 Torx bit. Or just let the dealer take care of it.
Freedom isn`t free. If you can read this, thank a Teacher. If it`s in ENGLISH, Thank a VET! The right to keep and bear arms shall not be infringed.....
EODHOG is offline
post #3 of 4 (permalink) Old 12-02-2015, 10:29 AM
9over's Avatar
Did you check the allen cap bolt under the speaker grill???
9over is offline
post #4 of 4 (permalink) Old 12-02-2015, 08:17 PM Thread Starter
I haven't done anything to the fairing. All I've tried to fix it so far is pushing on it with my hand to see if it would pop back in place. I haven't done much to the bike as a whole really. Hopefully the stock exhaust's days are limited. I'll take a look at the bolts you guys mentioned. Thanks.
USMCEOD is offline
Fix it or 2015? FIX! 08Zinc Engine Related 24 02-14-2017 06:26 PM
Fix a broken tab on inner fairing? Lunchboxx Do-IT-Yourself 15 07-09-2016 03:42 PM
Popped my fairing cherry Taco Bruiser Lighting 13 06-24-2013 04:28 PM
Popped cherry on 1000 mile maintenance Methos1979 Do-IT-Yourself 10 11-14-2012 04:19 AM
Head light bezel popped off alk Troubleshooting for Road Glides 4 10-29-2010 11:18 AM
