Fairing Mount, right side a little bent in. - Road Glide Forums
 4Likes
post #1 of 33 (permalink) Old 05-30-2016, 05:08 AM Thread Starter
So, back in 2014 I went down on my bike.
It was repaired by the local HD dealership, and insurance covered it. Well, during my radio installation I was about to take off the inner fairing and noticed as I was looking in-between the fairing and handle bars that the right portion of the fairing mount looks a little pushed in from when I laid it down and it slid into the bumper of a truck.
Now, after I laid it down, I noticed the right lower fairing doesn't fit, because it touches the bottom front fairing. So, that definitely makes me thing it's a little bent in towards the tank.
Do I need to buy a whole new mount or can I get like a rubber mallet and try making it straight again? It's barely noticeable that it's bent towards the tank, but when comparing it to the other side you can notice it.
2007 RG FLTR
dinggus is offline
post #2 of 33 (permalink) Old 05-30-2016, 11:19 AM
I would buy a new bracket that way you know the bracket is correct. Also look at the crash bar it may be tweaked a little.
I would install the 2010 and later brackets on your 07 if you're buying brackets but you would need to spend a bit more because you would need both outer fairing supports brackets and the main center support bracket.
I put the 2010 brackets on my 08 and put the vented fairing lower on the bike.
post #3 of 33 (permalink) Old 05-30-2016, 11:42 AM Thread Starter
I found the fairing bracket online for $66. The other brackets you're talking about, that's what mounts to the crash bar and the fairing mounts to that correct? If so, I'm reading I can get the Hell's Foundry Invisible bracket. It'll clean the look of the bike up as well.
How would the fairing bracket mount affect what lowers you have? I currently have non-vented ones and most likely want to just stick with those then eventually upgrade to vented lowers if needed.
I'm pretty annoyed that the dealership didn't fully inspect this, I even told them I tried to install the lower fairings after I received the bike back and all they could tell me is it might cost a few hundred dollars to figure out the issue and get it corrected.
2007 RG FLTR
dinggus is offline
post #4 of 33 (permalink) Old 05-31-2016, 06:54 PM Thread Starter
Just to clarify, I can get the 2010 fairing mount and the hell foundry invisible brackets, correct?
Looking at buying parts soon.
2007 RG FLTR
dinggus is offline
post #5 of 33 (permalink) Old 05-31-2016, 07:15 PM
Ranger1064's Avatar
Ghost Brackets
The Engine Guard with Fairing Supports: IE, support Fairing and also are components of the Directionals. Removing the Fairing Support Brackets & installing the Ghost Bracket will require turn signal mods. Not a Big Deal..just be prepared for it. Your going to require a few extra bolts as now the inner fairing requires a backing. Doing this will hinder lower installs. You will be using the center location of the Engine Guard to now install the Ghost Bracket as it now will support the weight of the Fairing. Follow? They are supported on the Engine Guard alone, removing engine guard setup..No Lowers...Factory 47 also makes Ghost Brackets if you get a chance to look at them.
2013 FLTRXSE2 "Atomic Hammer"
2012 FLTRX, 2004 RKC
Ranger1064 is offline
post #6 of 33 (permalink) Old 05-31-2016, 07:24 PM
RGKen's Avatar
You are not talking about the same brackets. I believe the OP is wanting to use the Hells Foundry Hidden Fairing Support Brackets that attach to the tank bolts and then to the turn signals. No mods required and you can still use the engine guard with lowers. I know as I have done this on 2 different bikes.
Dinggus- you will not need the original fairing support brackets when using the Hells Foundry brackets.
http://www.hellsfoundry.com/fairing_support_fltr.htm
2018 FLTRXS
RGKen is offline
post #7 of 33 (permalink) Old 05-31-2016, 07:37 PM
Ranger1064's Avatar
Well there you Go...i was wrong again...did not realize they connected to the tank...I removed a set on my 13 that attached at Engine Guard Location. So..Never Mind The Directional Issue will still need to be addressed..or I could be wrong again..Ha!
RGKen likes this.
post #8 of 33 (permalink) Old 05-31-2016, 07:55 PM
RGKen's Avatar
That's still not an issue. They come with shorter studs to go in the turn signals if you elect to use them.
2018 FLTRXS
RGKen is offline
post #9 of 33 (permalink) Old 05-31-2016, 08:08 PM
Ranger1064's Avatar
It's an issue if they are too long or too short there Silly. That could be an issue...lol..I know what your saying..I had a 12 and currently have a 13 and the 12 had studs the 13 does not...Hmmmm. so there could be some slight differences. All I was stating is he may have to address it. Either Way..it looks like he has a new project on the Horizon.
RGKen likes this.
post #10 of 33 (permalink) Old 05-31-2016, 08:26 PM
RGKen's Avatar
You don't use the acorn nuts if the studs are too long. Lock nuts and washers work just fine. That's the only mod needed if you want to call that a mod.
2018 FLTRXS
RGKen is offline
Right place. Right time. RFG7680 *General Road Glide Discussions/Pictures 10 09-24-2016 10:45 PM
WTB Right Side Vented Lower Fairing Cap lil chief Wanted! (Buy or Trade) 0 06-13-2016 06:11 PM
Right side 7.25 left side 5.25... Trak350 Audio 3 06-09-2014 09:28 PM
Ginz Choppers Hell Bent VividRGU Seating: seats, backrests 4 04-15-2012 07:38 AM
Is your frame cross member bent? jcanrun *General Road Glide Discussions/Pictures 7 01-05-2011 07:25 AM
