What is this and can and I remove it - Road Glide Forums
 6Likes
post #1 of 21 (permalink) Old 05-30-2016, 06:06 PM Thread Starter
What is this in the picture below (metal bar wrapping around the ask sest the seat) and can I remove it?
Sent from my LG-H901 using Tapatalk
2007 RG FLTR
dinggus is offline
post #2 of 21 (permalink) Old 05-30-2016, 06:12 PM
sj01fltri's Avatar
Yes you can remove it.I cut mine flush with the fender struts then pug them,it may hold your plate on so you will have to get a mount for your plate.
Smarty likes this.
sj01fltri is offline
post #3 of 21 (permalink) Old 05-30-2016, 08:26 PM
Triplej's Avatar
Try this out from Bad Dad,
Bad Dad | Custom Bagger Parts for Your Bagger | License Plate Eliminator Bracket
Triplej is offline
post #4 of 21 (permalink) Old 05-30-2016, 11:02 PM
skratch's Avatar
before you go cutting anything, I suggest that you have a backup plan in place. I cut it and plugged it on my 2007 road king. shortly thereafter, on a road trip, when I made a lane change, the thickness of the paint separating the lanes threw me into a serious speed wobble. an, 'oh shit, i'm gonna lose it', kinda wobble. this happened to me twice on that roadtrip. it had never happened before, and after I got home and put the bar back on, it never happened again.
other folks have done it and not reported any problems. that was not my experience. the 'older' swingarms just aren't as beefy as the newer ones and are more subject to twisting.
skratch is offline
post #5 of 21 (permalink) Old 05-31-2016, 01:28 AM Thread Starter
Thanks guys. So does it serve a purpose?
2007 RG FLTR
dinggus is offline
post #6 of 21 (permalink) Old 05-31-2016, 07:11 AM
That bar is a fender support bracket and licence plate holder. Mine broke on the flat parts that extend down and bolt to the fender, about one year ago. While sitting on the back seat my wife could feel the fender move, and when going over small dips on the pavement the fender would sink and drift right to left scrubbing the tire. Some folks do cut the u shaped extension and plug the ends but I think it is good to leave it intact. But just in case you do decide to try cutting it and don't like the result you can always buy another. Mine cost $130.00 Canadian last year. Oh ya. As long as no one was sitting on the back the bike road fine with the broken bracket.
grambo is offline
post #7 of 21 (permalink) Old 05-31-2016, 07:51 AM Thread Starter
I think it's ugly, but do I have to cut it to use Bad Dad License Plate Eliminator Bracket? (Bad Dad | Custom Bagger Parts for Your Bagger | License Plate Eliminator Bracket).
2007 RG FLTR
dinggus is offline
post #8 of 21 (permalink) Old 05-31-2016, 07:53 AM
Smarty's Avatar
Nearly everyone I know has cut that part of the upper support arms off and either put led blinkers in the end or a filler cap. I rode a 08 Road King like that for years with no problem.
2016 RGS Black Quartz
Smarty is offline
post #9 of 21 (permalink) Old 05-31-2016, 08:13 AM
Indyglide's Avatar
You don't cut it to use the bad dad bracket, you just remove it and put the brackets in place of it. Your rails will still be exposed but the hoop will be gone.
dinggus likes this.
Indyglide is offline
post #10 of 21 (permalink) Old 05-31-2016, 08:15 AM
Indyglide's Avatar
Here's what it will look like Image1464700511.989011.jpgImage1464700541.964281.jpg
dinggus likes this.
I Can't Wait I Can't Wait I Can't Wait......The Outdoors SteadyEddie General Off-Topic Discussions 15 05-19-2017 02:57 PM
Help - Can't remove windshield screw zigzag930 Windshields 6 04-27-2017 07:35 PM
Can you remove the CAT without welding? gorillaman Intake and Exhaust 9 11-03-2016 08:49 PM
Antenna, go with a hidden or can I remove it? Mooseinthetub Audio 17 02-22-2016 03:55 PM
Why can I remove the floorbaords?? I'm killing myself! ctalbot6983 *General Road Glide Discussions/Pictures 12 06-23-2013 10:39 PM
