Should there be a gap between fairing on my Rushmore RGS? - Road Glide Forums
 4Likes
post #1 of 17 (permalink) Old 02-12-2017, 10:12 AM Thread Starter
Anyone have a gap between their inner fairing and the top air vent assembly (part the windshield screws into) on their 2015-2016 road glides? I took my fairing apart yesterday to install some vent screens and did not take notice if this gap was there before I started. No matter what I do, I can't seem to get it to fully seat into the inner fairing. It is pretty uniform at about 1/8" all across the top, but it seems like it would be bad if water got in there.
macabra11 is offline
post #2 of 17 (permalink) Old 02-12-2017, 10:13 AM Thread Starter
Here is a shot from the right side on top
post #3 of 17 (permalink) Old 02-12-2017, 10:34 AM
lil chief's Avatar
I'm having a hard time trying to see in the pics where on the fairing/vent area you're speaking of, but just wondering, does the gap close up when you put the shield on & tighten up all the screws? I can't really tell on mine if there's a gap because the windshield is on, but IIRC, there is a slight gap between the two. Maybe pull your fairing back off & make sure there's nothing out of place under there that might be holding it from closing that gap up a bit more.
Lil Chief
lil chief is offline
post #4 of 17 (permalink) Old 02-12-2017, 10:46 AM Thread Starter
Here is a wider shot of where I am talking about.
post #5 of 17 (permalink) Old 02-12-2017, 11:52 AM
UT_Larry's Avatar
From the pictures it looks like the windshield is not installed. Should close when windshield is fully installed. If it doesn't I would take fairing off & reinstall.
FLTREX likes this.
UT_Larry is offline
post #6 of 17 (permalink) Old 02-12-2017, 12:06 PM
Desertwndrr's Avatar
It'll tighten up when you screw down the windshield. Don't over torque the screws. Snug, not tight.
FLTREX likes this.
2019 RGS, 2016 RGS, 2015 RGS
Desertwndrr is offline
post #7 of 17 (permalink) Old 02-12-2017, 12:25 PM
BlazingSaddle's Avatar
There's no problem. Mine's exactly the same. Fits a little more flush (still a small space) above the radio/below the opening of top vent, then gradually tapers to more space (about what your picture shows) on the sides, moving from the center of top vent towards the outer part (towards edge of windshield) of the fairing. I've never had my fairing off.
BlazingSaddle is offline
post #8 of 17 (permalink) Old 02-12-2017, 12:43 PM Thread Starter
Thanks guys, my new windshield should be here on Tuesday so I will report back after I get it installed and properly torqued down.
post #9 of 17 (permalink) Old 02-20-2017, 10:38 AM
I am glad you posted this. I noticed the EXACT same thing when I installed a Hogtunes amp. I thought maybe the amp, or my wires, were somehow getting in the way and stopping it from closing correctly. I took it apart a couple of times to see if the gap would go away, and it didn't. Like you, I did not notice it before I took the fairing off. I thought I had something misaligned, but after seeing your post I guess it is a factory defect in alignment (at least on our two bikes).
I can get mine to squeeze together, but as soon as I let off pressure, it goes back to the small gap. I had a thought to use a velcro strap on both pieces (from the inside) to hold it together - maybe if I have a need to take the fairing off again I will see if that works.
RGBob is offline
post #10 of 17 (permalink) Old 02-20-2017, 11:13 AM Thread Starter
Yep, this is the same with me. I installed my windshield and the gap remains there. It sort of has me freaked out about getting water down inside the fairing where all the electronics are. I know these bikes aren't sealed up SUPER tight, but I doubt having large gaping openings is going to help any. Maybe I'm just stressing over nothing.
Gap between top vent and inner fairing on Rushmores apd240 Tech Area 8 06-14-2016 05:02 AM
Gap between inner and outer fairing icufltrn Paint & Bodywork Section 22 05-21-2016 05:06 AM
15's and 16's Who else has a gap between their inner and outer fairing? USMCEOD *General Road Glide Discussions/Pictures 24 02-04-2016 09:54 PM
06 dealer takeoff seat has 1/2" gap between seat and console on my 02 chevjerico Seating: seats, backrests 7 10-30-2013 11:17 AM
Gap between W/S & inter-fairing twowheel99 Windshields 7 02-24-2011 09:32 PM
