Warranty question - Road Glide Forums
post #1 of 7 (permalink) Old 02-18-2017, 10:08 AM Thread Starter
rdrnr03's Avatar
Warranty question
I have a 09 with a extended warranty. I noticed that the middle front fairing screw was not tight. When I tried to tighten it I noticed the little plastic screw nub on the outer fairing was broken off on the screw. Is this something that the warranty will cover.
rdrnr03 is offline
post #2 of 7 (permalink) Old 02-18-2017, 01:39 PM
Are you talking about 1 of the 5 screws that goes through the windshield?
If it is they are actually well nuts that are easily replaced and IMHO would not be covered under warranty. If its not one of those screws, never mind.
thealien is offline
post #3 of 7 (permalink) Old 02-18-2017, 02:13 PM Thread Starter
rdrnr03's Avatar
It is where you screw the the outer fairing on. Not the wind shield.
rdrnr03 is offline
post #4 of 7 (permalink) Old 02-18-2017, 03:44 PM
As far as I can remember there is not a "middle" screw that holds the outer fairing on?
There are the bolts that hold the directional on that also sandwhich the two halves of the fairing on. Then there are three screws on each side that go through the inner fairing and screw to the outer fairing.
Which screw is it?
Is it number 2 or 3 in this diagram?
Parts Finder Doc's Harley-Davidson of Shawano County, WI Bonduel, WI (715) 758-9080
or number 1 in this diagram?
thealien is offline
post #5 of 7 (permalink) Old 02-18-2017, 06:07 PM
Bleachey's Avatar
Not sure which screw you re exactly talking about, but my outer fairing broke where the screw goes into it. It was not covered by the ESP. I wasn't happy, but luckily a good friend was able to help me do some fiberglass repair.
2011 Road Glide Ultra
Bleachey is offline
post #6 of 7 (permalink) Old 02-21-2017, 07:15 AM
If you do a search on this forum you will find a few ways to repair.
Here is one https://www.roadglide.org/29-do-yours...crew-hole.html
tOSUSteve is offline
post #7 of 7 (permalink) Old 02-26-2017, 10:31 AM Thread Starter
rdrnr03's Avatar
Thanks for the replies. I found out it wasn't covered under warranty but ended up fixing it myself. Pain in the ass but it worked.
rdrnr03 is offline
Extended Warranty Question 100edition New Members Welcome Area 13 03-12-2013 11:53 AM
Extended warranty question... Johnzz1420 *General Road Glide Discussions/Pictures 4 07-12-2012 09:39 AM
Outer fairing fit and warranty question??? bad86ta *General Road Glide Discussions/Pictures 13 03-03-2012 11:38 AM
Warranty Question DAWG_6 Seating: seats, backrests 7 03-23-2011 06:39 PM
Newbie warranty question musicman8120 *General Road Glide Discussions/Pictures 4 08-19-2010 05:53 PM
