mold between tour pack and badkrest - Road Glide Forums
post #1 of 3 (permalink) Old 02-21-2017, 01:38 PM Thread Starter
does anyone have a solution for the mold build up between the tour pack and the rider backrest. I've tried everything that i thought would work thanks.
dawgrgc1 is offline
post #2 of 3 (permalink) Old 02-21-2017, 01:55 PM
Clorox? Don't lick it! Did you not watch that famous hygiene film in heath (sex Ed.)class!? Lol
dozer23 is offline
post #3 of 3 (permalink) Old 02-21-2017, 03:18 PM
BlazingSaddle's Avatar
Could you elaborate a little more? Is the issue that it won't come off at all, or it comes off, but returns, and then, what methods have you already tried?
Also, when you say between the tour-pak and backrest, do you mean along the top of the backrest where it meets the paint, or under the flap (you didn't specify which tour-pak you're using). I'd remove the backrest from the tour-pak and clean it.
Either way, should come off easily with soap, water and a brush, maybe a little cleaner wax, or even a light compound. If it's not coming off the paint and you've tried everything, sounds like maybe it's damaged the paint.
What I wonder is how it got moldy in the first place? Figure that out, and address it (i.e. cushion absorbs and holds water, causing mold, parking it under trees for extended periods of time, etc.).
BlazingSaddle is offline
15's and 16's Who else has a gap between their inner and outer fairing? USMCEOD *General Road Glide Discussions/Pictures 24 02-04-2016 09:54 PM
WTB King Tour Pack for '86 FLTC Tour Glide Classic. JohnnyC Wanted! (Buy or Trade) 5 12-24-2014 02:12 PM
Distance between tour pack mount and rear seat bolt.... SEsupply2 Equipment-RG 8 10-14-2014 07:15 PM
Trying to decided between Road Tech 660 and 665 G Audio 9 02-21-2011 08:30 PM
difference between tour pacs SWFLGLIDER Aftermarket Accessories 2 03-22-2010 08:05 AM
