Need options for replaceing weatherstripping - Road Glide Forums
post #1 of 17 (permalink) Old 09-29-2013, 09:53 PM Thread Starter
Hello,
One of the flaws that seems to be common in every "Glide" motorcycle is that the black weatherstipping between the inner and outer snakes right out. I left mine out because it was so out-of-spec and I had no new. Im not sure I want to go back to the OEM style anyway. A friend in my congregation has a Street Glide and this is a problem for him too. What are my options for a higher quality weatherstrip that will stay put? Also I have a Windvest sheild and I do not know if it a factory part but the weatherstripping on the lower edge of this is not impressing me either.
I never saw a wild thing feel sorry for itself.--DH Lawerence
Tackdriver is offline
post #2 of 17 (permalink) Old 09-29-2013, 10:00 PM
Workman's Avatar
try X-trim they sell a kit for both fairing and the windshield - I put it on early this spring and have about 15K miles since with no issues at all.
http://www.xcycletrim.com/
Workman is offline
post #3 of 17 (permalink) Old 09-29-2013, 10:07 PM
zemo1017's Avatar
X-trim
X-trim all the way. Just google xtrim and it will take you right to it.
zemo1017 is offline
post #4 of 17 (permalink) Old 09-29-2013, 10:12 PM
ERod62's Avatar
X-Trim works well. Same can be found on auto parts at lower price.
Used on the fairing and wind shield.
ERod62 is offline
post #5 of 17 (permalink) Old 09-30-2013, 05:19 AM
go to your local auto parts store and get door edge Gard for a car, i got mine at advance auto, its a tiny bit wider then stock HD so it fills space very well, you will probably have to heat it with a hair drier to make it easy to put on
danko is offline
post #6 of 17 (permalink) Old 09-30-2013, 09:37 AM
Fenny's Avatar
Another vote for X-trim here. Secure, goes on easy, & no adhesive needed.
2004 FLTRI - Custom Paint: Glacier White Pearl & Vivid Black with Blue Flake, 12" Buky Malos, Dragos Dragula, Monroe DIY Air Shocks
2001 XLH1200 - Black & Chrome
Fenny is offline
post #7 of 17 (permalink) Old 10-03-2013, 12:12 PM
can adhesive be used? the stock stuff oozes out when hot. recommendations on better adhesive?
thanks in advance
Sledbum is offline
post #8 of 17 (permalink) Old 10-03-2013, 12:24 PM
JacktheBagger's Avatar
another x trim advocate
with x trim you don't need any adhesive
with the factory stuff some say caulking or a light bead of roofing tar from a tube , but I did those and they were even messier
JtB
2011 Ultra
JacktheBagger is offline
post #9 of 17 (permalink) Old 10-03-2013, 02:03 PM
DED HD's Avatar
i used the Door Edge guard from Auto zone on my windshield. looks and works great! just now starting to have some issues with the weather strip on the left side of the fairing by the glove box, so no experience with xtrim.
'10 Red Custom:
DED HD is offline
post #10 of 17 (permalink) Old 10-03-2013, 02:13 PM
After 8 yrs, say WTF for took it off, used wellnuts (with larger thin neophrems) longer with raised buttons. Still an't figured out what the strip is good foe except to place in parts boxes with $hit like the belt gaurd. No the rain don't get in or(wind whistle @ or if it does who cares you wet on a bike, the dash mainly dry. that was two yr ago, seal the inner Shit..... cosmetic!!!
reds4 is offline
Bought solo seat need better fastener options 90b4032 Seating: seats, backrests 6 04-19-2016 06:25 PM
KW 12" too short, need options Fillatre Windshields 18 07-24-2014 10:47 AM
NEED Timken part ##'s or Options 2010 ABS h-donut Do-IT-Yourself 2 03-26-2013 01:56 PM
Headlight covers - blackout options CHAINSAW Lighting 53 04-03-2012 04:33 PM
Gauge LED Color Options / Availability Shrug *General Road Glide Discussions/Pictures 29 10-16-2011 10:56 PM
