Rear tri bar cover removal - Road Glide Forums
post #1 of 8 (permalink) Old 09-30-2013, 03:12 PM Thread Starter
jims13RG's Avatar
OK WTF, i have a new rear light bar/plate holder powder coated and attempting to install it but i cant get the cover off of the back of the tribar to unhook the wire, any fill this idiot in please
jims13RG is offline
post #2 of 8 (permalink) Old 09-30-2013, 03:28 PM
PGR
PGR's Avatar
What year, what model?
You could try here http://www.tnt-actionsports.com/OEMpartfinder.htm ..... sometimes you can get a clue as to how it's assembled from the drawings.
Ron..........................
PGR is offline
post #3 of 8 (permalink) Old 09-30-2013, 03:44 PM
TLWiz's Avatar
I think that you unhook the wire at the other end, where it has a plug connector.
TLWiz is offline
post #4 of 8 (permalink) Old 09-30-2013, 04:29 PM Thread Starter
jims13RG's Avatar
2013 fltrx
jims13RG is offline
post #5 of 8 (permalink) Old 09-30-2013, 04:35 PM Thread Starter
jims13RG's Avatar
it unplugs under the cover on the tribar. Seems easy enough just pop off the cover and unplug the damn thing. No luck, its going to piss me off if I have to pull the rear wheel in order to get more room.
jims13RG is offline
post #6 of 8 (permalink) Old 09-30-2013, 05:00 PM
DewmanCO's Avatar
It is a real pain to get back there but you can do it without pulling the rear wheel. Do you have a shop manual? I pulled the rear fender off to get to mine. I sent my rear tail light bar to Jetman for powder coating and I had to take the rear fender off to cleanly take that whole tail light section apart. If you have a manual it shows you how to do it but it is super tight between the tire and the light... I just pulled the fender off to give me more room to work.
Mathematics - as relentless as the laws of gravity - is nonnegotiable
DewmanCO is offline
post #7 of 8 (permalink) Old 09-30-2013, 06:44 PM
If you have a motorcycle jack lift it up and remove the lower shock bolts on both sides. That will give you enough room to stick your hand in
post #8 of 8 (permalink) Old 09-30-2013, 07:17 PM
jack6hd's Avatar
Did the same. Patience
2015 FXDL 2nd best HD on road
jack6hd is offline
Rear Tri-bar tailight...? HDrider1 Lighting 12 01-12-2013 09:22 AM
WTB rear fascia tri bar light. BFMC32 Wanted! (Buy or Trade) 5 02-27-2012 10:49 PM
Rear Fascia with Tri-Bar Light on Ebaymotors PBSTN Aftermarket Accessories 0 02-19-2012 07:41 PM
Tri bar/Street glide - FLTRX rear facia custom setup *price lowered* CHAINSAW Classifieds Archive (3 months old+) 4 01-06-2011 10:25 AM
