Powder coating lightbar and markers????? - Road Glide Forums
post #1 of 5 (permalink) Old 11-06-2013, 08:15 AM Thread Starter
So my question is how do you or can you powder coat these pieces with the bulb socket and wires still attached? I am thinking no, so please fill me in! Thanks all.
2010 FLTRX- Black Denim, Rev Tech Dominator 18's w/matching rotors, RSD grips, RSD air cleaner, Vance and Hines pro pipe, Power commander V, chopped wind screen.
Torkmnstr is offline
post #2 of 5 (permalink) Old 11-06-2013, 08:22 AM
Q-Hog's Avatar
If your referring to the stock front turn signals, all you got to do is unplug the lights from the inner fairing, take bulbs out, use a fine flat tip screwdriver & pluck the inner base out, it will come out. Once you pluck it, you will have to cut the wires to pull the wires through. Don't sweat cutting the wires, All you have to do strip the wires and use a connection method as you like to put I back together again. Easy mod to do..
Q-Hog is offline
post #3 of 5 (permalink) Old 11-06-2013, 08:28 AM
DED HD's Avatar
you do need to remove the housing and wires before coating.
I didnt cut any wires, i simply pulled them through the housing after removing the wires from the plugs. Take pictures and label the wires.
'10 Red Custom:
DED HD is offline
post #4 of 5 (permalink) Old 11-06-2013, 08:43 AM
Q-Hog's Avatar
DED, you're right. You can pull the wire out of the connectors, It was easy for me to just cut it, connect it back & heat shrink it.
Q-Hog is offline
post #5 of 5 (permalink) Old 11-06-2013, 09:27 AM Thread Starter
Yea I thought you could remove the socket portion but I wasn't sure where to start. Thanks for the input all.
Pnw powder coating and more Rowdy General Off-Topic Discussions 0 06-26-2012 08:00 AM
Check out these Hot Legs / forks. And some powder coating clloyd *General Road Glide Discussions/Pictures 19 01-19-2012 12:33 PM
cvo rear turn signals/lightbar-touring cestaro Classifieds Archive (3 months old+) 0 11-28-2011 03:20 PM
More powder coating done FLTR2008Trike *General Road Glide Discussions/Pictures 2 02-20-2010 03:02 PM
Powder Coating ATrain *General Road Glide Discussions/Pictures 8 01-19-2010 07:08 PM
