Fuel Tank Question - Road Glide Forums
post #1 of 4 (permalink) Old 11-11-2013, 03:04 PM Thread Starter
Fuel Tank Question
OK Guys I have searched everywhere and either I am not able to articulate what I am looking for or no one has done this before, I am betting on the first.
I am wondering if a fuel tank from an 1998 - 2007 road glide would fit on an 1986-1996 tour glide. I am looking at aftermarket tanks and the only ones I find are for 1997 up. I am thing it would fit the only changes I know of are the lower seat on 1997 up but I cannot afford to spend 400.00 plus on a guess. thanks for any knowledge on this
htlal is offline
post #2 of 4 (permalink) Old 11-11-2013, 03:44 PM
RoadHawg's Avatar
Its unlikely to fit unless you modify the mounts which shouldn't be to hard on a bare steel new tank before painting.
Mikes Hawg Paint, Camino, CA.
RoadHawg is offline
post #3 of 4 (permalink) Old 11-11-2013, 07:04 PM
Pretty sure it's not going to fit, then the gromet placement to re-fit, fuel pump ect....Jack the Bagger oughta know
reds4 is offline
post #4 of 4 (permalink) Old 11-11-2013, 11:58 PM
JacktheBagger's Avatar
Thanks Reds
probably not , I'm pretty certain the mounting tabs are different
and you are taking a tank designed for fuel injection and putting it on a carb bike , there are some difference in the tanks for that , can be modified , but ..
You should be able to find a used tank for any FL series from your bikes year range
TG's are cool
JtB
2011 Ultra
JacktheBagger is offline
New fuel tank question MightyWhitey ECM/Fuel Management systems 2 10-30-2016 11:30 AM
any good instructions to remove 2011 fuel tank to replace fuel filter? CPY84 Do-IT-Yourself 9 10-10-2016 11:31 PM
Gas tank and fuel pump question jim_b Troubleshooting for Road Glides 3 05-20-2012 11:04 AM
Didn't someone with an 09 RG find a HD tank badge that covered the tank decal? scott *General Road Glide Discussions/Pictures 5 02-25-2011 01:09 PM
Fuel tank console MikeyTX *General Road Glide Discussions/Pictures 24 07-05-2010 01:29 PM
