Matching paint color issues - Road Glide Forums
post #1 of 8 (permalink) Old 11-22-2013, 02:33 PM Thread Starter
Guys I have a 09 SERG (electric Orange) that I am replacing the lids. My painter is have a difficult time getting the paint to match. Its to dark, to light, not enough flake. we are thing there is some method to this madness. I believe we ordered the right paint codes and he is one of the best I know with paint and bodywork for car. when we thnk its right and we add the pearl now its not. Anyone have any detailed instructions to share.
BigLew
BigLew is offline
post #2 of 8 (permalink) Old 11-22-2013, 02:48 PM
RoadHawg's Avatar
Electric Orange 925676 is the PPG code and that is what you should be using, it is NOT a special order color so your local jobber can mix it for you.
Like I've said, the orange shade colors are the toughest to match but not impossible with a bit of patience and the right formula.
If he looks at the "recipe" that makes up the base and tinted layers he will know what toners to adjust a bit to get a good match.
Mikes Hawg Paint, Camino, CA.
RoadHawg is offline
post #3 of 8 (permalink) Old 11-22-2013, 02:52 PM Thread Starter
Mike thanks I guess. I will pass it along but im not sure this ends up being anything but guess work.
BigLew is offline
post #4 of 8 (permalink) Old 11-22-2013, 02:55 PM
RoadHawg's Avatar
Skilled guess work at best
You are using the PPG formula right?
RoadHawg is offline
post #5 of 8 (permalink) Old 11-22-2013, 03:06 PM Thread Starter
I believe that is where we got the paint using that number. Is that what formula means?
BigLew is offline
post #6 of 8 (permalink) Old 11-22-2013, 03:08 PM
RoadHawg's Avatar
Yes it is, PPG is the OEM supplier to HD so you have the best chances of a match when you use the brand that is on the bike
RoadHawg is offline
post #7 of 8 (permalink) Old 11-22-2013, 03:12 PM Thread Starter
OK so is there any rule of thumb on how much paint,toner, pearl, clear to shoot? it seems when you get the paint right then add the clear/pearl it lightens or darkens the paint?
BigLew is offline
post #8 of 8 (permalink) Old 11-22-2013, 03:32 PM
RoadHawg's Avatar
That is where a painters "bag of tricks" expertise comes in handy, I always shoot a test panel along side of the actual parts, that way I can play with the sample and take note of what I did along the way to get a match, then I will do the parts.
I have a bunch of old broken saddle bags that I cut up to use as test panels
The clear is the final step of course, but sometimes you have to adjust the main layer and other times the tinted layer...there are no set "rules" to follow other than the basic instructions on the tech sheet of the paint product that pertain to cure times, reducing, etc.
RoadHawg is offline
CVO Color Matching Seadog Paint & Bodywork Section 31 09-27-2017 09:09 PM
Color Matching Cosmic Blue Pearl boosted20v Aftermarket Accessories 5 09-16-2016 06:01 PM
Color matching Venomized Paint & Bodywork Section 4 02-07-2014 10:00 AM
Black Denim paint matching problem pasa Paint & Bodywork Section 53 08-05-2012 01:20 AM
any matching or near match paint in a rattle can xshovelfreak Paint & Bodywork Section 1 10-02-2011 02:09 PM
