How to lower stock front fender? - Road Glide Forums
post #1 of 20 (permalink) Old 12-02-2013, 02:24 PM Thread Starter
Is there a mounting kit or similar that will lower the front fender? I have a 19" Agitator up front. I would like the stock fender to sit a little tighter on the tire. Was hoping there was an easy way to do that... I really want to stay with my stock fender.
Halstem1 is offline
post #2 of 20 (permalink) Old 12-02-2013, 02:28 PM
Bluchevypick's Avatar
Simply drill your holes out a little and bring it down.
Bluchevypick is offline
post #3 of 20 (permalink) Old 12-02-2013, 02:45 PM
Shark of the Month August 13
SIC_26's Avatar
Don't think that will get the fender down far enough, I'm assuming you want to tip of the fender down tight, roughly 1.5" or so.....Native Custom Baggers makes a fender lowering kit, drill the rivets out of the OEM fender, moch up the brackets and test fit, weld and repaint that's the best/cleanest way to go about it. Plus it leave you with a clean, rivet less, fender in the end :thumbup:
I've done a few in the past with great success, mike has also posted some pictures in the past of fenders that he's shaved the rivets on....the look itself is worth the effort!!
SIC_26 is offline
post #4 of 20 (permalink) Old 12-02-2013, 03:17 PM
runmanpkll's Avatar
native custom baggers also has a bolt-on kit available if you don't want to weld and repaint. you still need to drill out the old rivets then the bolts use the rivet holes.
2011 FLTRX Sedona Orange
runmanpkll is offline
post #5 of 20 (permalink) Old 12-02-2013, 04:53 PM
Redbeard77's Avatar
Thanks for the tip! I like the stock fender and keep going back and forth between a 21 or fat 18. Also, I agree the Agitator will look better with less tire gap. I wasn't familiar with Native Custom Baggers, but they have some cool stuff. http://www.nativecustombaggers.com/i...ering-kit.html
Happiness is a warm motorcycle.
Redbeard77 is offline
post #6 of 20 (permalink) Old 12-02-2013, 05:30 PM
RoadHawg's Avatar
The 21" wheel/tire combo makes the stock fender gap look ok without using a lowering kit.
Shaving the rivets give it a nice smooth look!
Mikes Hawg Paint, Camino, CA.
RoadHawg is offline
post #7 of 20 (permalink) Old 12-02-2013, 05:56 PM
GMONEY's Avatar
Location: LexVegas, KY...home of fast wimmen & beautiful horses
Keep the 19" and lose the stocker.
\_/ Chicks Dig Ape Hangers \_/
IronButt Assoc. #27301
Combat Vets Motorcycle Assc. (KY 1-1 original chapter)
GMONEY is offline
post #8 of 20 (permalink) Old 12-02-2013, 08:21 PM
twistr's Avatar
try this place...I have something similar but looking to go back to stock:
http://bitchinbaggers.com/products/b...drop-brackets/
Riding Life's Twisting Roads...
On a 2008 Dark Blue Pearl Road Glide
twistr is offline
post #9 of 20 (permalink) Old 12-02-2013, 10:23 PM
skratch's Avatar
do it the way i did. put your bike on a lift, and then lower it just a tad too far so your bike falls over and dings up the front fender. freak out, scream and holler, and cuss a bit. get the bike picked back up and go in the house in frustration. calm down, call the insurance agent and make a claim. when insurance agent comes out and cuts you a check, order a primed cvo fender and send it off to be painted your color of choice (in my case, big blue pearl). when it comes in in a couple of weeks, remove old fender and replace with new, lowered fender..... (wheel is a 19'' agitator)
*****i really don't recommend doing it this way, but it did work for me******
skratch is online now
post #10 of 20 (permalink) Old 12-03-2013, 04:47 AM
BackRodes's Avatar
Check the thread "Front fender slam kit".
Heaven is a sweeping mountain road in the mirrors.
BackRodes is offline
If I lower the rear do I have to lower the front?? StrokerAce Suspensions 13 11-17-2013 01:32 PM
Black Pearl front fender w/ Willie G Fender skirt sabre0909 Classifieds Archive (3 months old+) 4 12-19-2012 02:11 PM
21 front, should I lower the front (RGU) Flexin Wheels and Tires 4 11-29-2012 02:23 AM
Fatboy front fender, bad dad 1in fender spacers 11FLTRX103 Classifieds Archive (3 months old+) 4 08-04-2012 07:05 PM
Best way to lower the front fender? Xaran Paint & Bodywork Section 8 05-09-2012 11:43 PM
